Loaded 2022 / 3d not visible
2022 regenerate 3D view
#1 Amanda Taylor
Amanda Taylor
  • 4 posts
Posted 28 April 2021 - 09:59 AM
Has anyone recently loaded SoftPlan 2022, but there's some disconnect and the 3d views aren't loading? This worked fine with the trial version I just had. Support is looking in to it too, but just wondering what I need to look in to, if anyone has had a similar issue. Pushing regenerate does nothing. The 3D Textured tab name is a lighter shade of gray even, so I know it's not working. Thanks!
Also wondering if I should start on a slightly older version if there's issues with 2022.
#2 Joseph Smith
  • 824 posts
Posted 28 April 2021 - 11:00 AM
start with the most basic least processor intensive views which are wire frame.  then in navigation menu pick the center circle, this should give you a view direct....if you can see this, you should be able to change to other 3d modes.
#3 Fred Russell
Fred Russell
  • 616 posts
Posted 30 April 2021 - 05:08 PM
Don't think there's an issue with 2022 3d, so probably figure what setting you don't have right. Start with if the plan is sitting as a model.
I've a couple times had to click and move mouse across screen to get it to start. Never figured why, think maybe that starts regenerate.
I'm having my best looks so far without using Path Tracing, and then have that good control of the Ambien light and with the Tone mapping
Also tagged with one or more of these keywords: 2022, regenerate, 3D view
