Add False Gable
10 replies to this topic
#1 Russ Wolfe
Russ Wolfe
  • 8 posts
  • LocationManitoba
Posted 03 May 2021 - 10:45 AM
Hello all, Been using Softplan for about 14 years now the latest I was using was 2016 now I'm on the 2022 Softplan+.
Having trouble with the add false gable function. Before it was just click on the 2 points you wanted and boom there was a gable. Trying that now and it doesn't work.
I have tried cutting a hole then adding the gable and no such luck. The roof on opening function works but where I need the roof there isn't an opening.
Can someone shine some light on this for me please?
Posted 03 May 2021 - 11:18 AM
It should workk exactly like it did. Choose DRAW > ADD FALSE GABLE, and then you trace the gable edge on the eaves.
#3 Philip Meade
Philip Meade
  • 2 posts
Posted 03 May 2021 - 11:44 AM
false gable and cricket do not work in 2022
Softplan is working on it.
#4 Russ Wolfe
Russ Wolfe
  • 8 posts
  • LocationManitoba
Posted 03 May 2021 - 12:40 PM
I was thinking it should too Keith.
Thank you Phil!!
#5 John Pepper
John Pepper
  • Administrators
  • 406 posts
Posted 03 May 2021 - 12:59 PM
The 2022.2.8 patch should fix this issue.  File->System Options->System Options->Check for Updates
#6 Russ Wolfe
Russ Wolfe
  • 8 posts
  • LocationManitoba
Posted 03 May 2021 - 01:03 PM
When I checked this morning there were no updates.
There is now, fingers crossed!
#7 Russ Wolfe
Russ Wolfe
  • 8 posts
  • LocationManitoba
Posted 03 May 2021 - 01:20 PM
Sure enough, Thank you Softplan!!
Next thing I am wondering about is, is anyone else having an issue using with the multiple floor roof function.
I have a 2 story house with the 1st story having multiple wall heights so i drop the floor system to the right height. I put a roof on the 2nd level and it works good, put the roof on the 1st level and on the plan it looks good but in the elevations its raised by the amount of drop I had to put in the 2nd floor. I feel like it takes reference off of the floor not the wall or beam it should be. Should have a 12" heel like the 2nd level but has a 21.5" heel instead.
I hope that makes sense. Not sure if anyone is experiencing something like that also.
Posted 03 May 2021 - 01:25 PM
My FALSE GABLE works fine in 2022.2.6, I can't say i've tried a cricket.
#9 Ron Mejeur
Ron Mejeur
  • 66 posts
  • LocationKalalmazoo, Mi
Posted 04 May 2021 - 01:17 PM
False gable worked fine in 2022.2.6 but didn't work correctly in 2022.2.7.  The new update (2022.2.8) took care of the issue and works again.
Ron Mejeur
#10 Jacob Christensen
Jacob Christensen
  • 3 posts
Posted 09 August 2021 - 10:02 AM
I am having an issue with false gable not lining up edges with existing main roof hip. On the roof plan it shows like all lines match up with no issue but once i go to the 3d or elevation views there is a disconnect. Anyone know what the issue is? Ive attached pictures of what I am seeing
#11 Joseph Smith
  • 824 posts
Posted 09 August 2021 - 10:21 AM
Is it possible for you to combine your two roofs and to have your false gable overhang 1/4" more then the eave overhang?  That's the way i manipulate a false gable using 1 roof vs 2 roofs.
  • Richard Rubinski likes this
