walls unconnecting
#1 Thomas Roman
Thomas Roman
  • 341 posts
  • LocationSacramento, CA
Posted 07 May 2021 - 10:51 AM
Can anyone see if they can repeat this hiccup ?
WARNING.. Do this on something that is NOT important.. make a COPY of a plan first..
It seems if I turn the visibility of the layer that contains the walls OFF.. (I was turning off ALL the layers except for one specific layer)... Then turn visibility of that layer ON again... When I do this, the wall endpoints are all no longer joined.. See attached Image
I have to close the project, then reopen the project in order to get all the walls to re-join endpoints..
The biggest problem with this is that all the dimension extension lines are compromised...
  • 5,092 posts
Posted 07 May 2021 - 11:15 AM
Sorry Thomas, I can't make it happen.
It may be something to do with walll join tolerance on some of the interlocking walls.
Can you make it happen on a drawing where the wall joins are simpler than that one?
#3 Thomas Roman
Thomas Roman
  • 341 posts
Posted 07 May 2021 - 11:56 AM
hmmm.. thanks.. i'll load another project and give a try..
#4 John Pepper
John Pepper
  • Administrators
  • 406 posts
Posted 07 May 2021 - 12:14 PM
Thomas, if you have a repeatable case, please submit a ticket on the project.
