Are any of you with the 3Dconnexion spacemouse experiencing any issues lately? I have two of these and both are having issues with maneuvering around ANY of my models.
Posted 10 May 2021 - 09:04 PM
Posted 11 May 2021 - 08:52 AM
I've updated the drivers and still the navigation is not working as it used to. I have to continue to go to the model's camera view and reset the 'center focus'. The center focus target seems to move as I rotate in 3d. Is there a way to lock this center? Or maybe the center focus target should move as I navigate....but the mouse should be in control of the target, shouldn't it?
Home Assurance LLC
Home Inspection
Project Consulting
Architectural Design
#5
Posted 17 May 2021 - 12:08 PM
Have you looked at the advanced settings in the 3D Connexion driver. You should be able to change from 'Object Mode' which it sounds like you are in, to 'Camera Mode' which is what you want. I had an issue not long ago when I updated my driver that it was stuck in the mode you are describing and I didn't have an option to change it. 3D Connexion tech support had me uninstall the driver, remove all of the registry entries and reinstall the drivers. It worked perfectly after that.
