Drawing want appear
Started by
Guest_C Davis_*
, May 21 2021 10:55 AM
#1
Guest_C Davis_*
Posted 21 May 2021 - 10:55 AM
I saved a drawing. Go back to open it and no drawing appear! The name I gave it still appears and the size of the file appears, but when I try to open it it's says "untilted" and shows a blank screen!!!
Same thing happens at check points!!What can I do to retrieve that file. Spent 2 days on this one drawing!! ANY IDEAS!!!THANKS SO MUCH!!!
Posted 04 June 2021 - 01:11 PM
Check your save path, if you saved the drawing, it WILL be saved somewhere. 'untitled' sounds like you converted to shapes then saved it possibly....difficult to say. Check the recovery folder within the project and look for .spd files....at this point be very careful, you are getting close to loosing data so if you find one with your 2 days worth of work save it properly with an actual name.
