how can I easily flip a wall?
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 29 June 2021 - 08:44 AM
How can I reverse the exterior face of a wall easily?
In Revit it is spacebar, is there a quick command other than checking the box in the navigation bar?
Also, is there an easy way to undo work instead of the icon too? Seems like control+Z doesn't work?
#2 Bryan Schultz
Bryan Schultz
  • 72 posts
Posted 29 June 2021 - 09:27 AM
Right Click on wall/Select Edit - half way down under Display you can change exterior side top/bottom --- left/right
Backspace = undo
#3 Henry Buckner
Henry Buckner
  • 342 posts
The "backspace" key is also the "undo" key. It works multiple times but I don't know how many.
If you edit the wall, there is a box that shows the exterior of the wall as left/right or up/down. You can change it there.
Posted 29 June 2021 - 10:21 AM
CTRL-Z is zoom in Softplan.
You could also CTRL-SELECT the wall and use the reverse command.
#5 John Jones
John Jones
  • Administrators
  • 251 posts
Posted 29 June 2021 - 01:21 PM
The real question may be why you have to flip an exterior wall.  It would typically be a seldom used action.  https://youtu.be/CcgHvF-gFHsshows how the exterior side of wall is indicated at draw time.
#6 Thomas Roman
Thomas Roman
  • 366 posts
  • LocationSacramento, CA
Posted 29 June 2021 - 01:51 PM
I agree John .. I need to "flip" the exterior side of a wall perhaps once every month or two... if that often..
But it does not surprise me that you need to do it so often in Revit, that there is actually a keyboard shortcut to perform the operation.. LOL...
