Deck Stairs not display correctly.
Deck plan display
#1 Neil Dickenson
Neil Dickenson
  • 14 posts
  • LocationAuckland New Zealand.
Posted 13 August 2015 - 08:48 PM
Does anyone have a solution to fix the bottom part of the steps going down from a landing cutting into the deck above?
Very frustrating and looks bad on the plan.
#2 Steve and Carla Farnam
  • 655 posts
Posted 13 August 2015 - 09:04 PM
Neil if you explode the stairs you will be able to erase the unwanted lines that show on the plan view.
#3 Neil Dickenson
Neil Dickenson
  • 14 posts
Posted 13 August 2015 - 10:29 PM
Thanks for that Steve (or Carla).
Tried that but the stairs disappear from the 3d view?
It does fix the plan view though, still I need the stairs to stay intact.
#4 Brad Graber
Brad Graber
  • 295 posts
Posted 14 August 2015 - 05:47 AM
Make a copy of the stairs and place it right on top of the other one.  Put one of the copies on a layer and turn it off.  Even with the layer turned off it will still show in 3d.  Now you can explode the remaining stair and make it look as you wish.
#5 Thomas Davis
Thomas Davis
  • 301 posts
Posted 14 August 2015 - 10:15 AM
maybe put deck stairs on first floor plan, and landing on second floor plan
copy the stairs to both floor plans, but explode on only one, so you can modify it and it will not show up in 3D
If you don't need to make modifications, there is no need to explode it, you can just hide it from Softview.
#6 Neil Dickenson
Neil Dickenson
  • 14 posts
Posted 14 August 2015 - 02:53 PM
Thanks for your ideas Brad and Tommy
Both those will work as a work around.
Cheers
Neil
Also tagged with one or more of these keywords: Deck, plan display
