How can I stop my underlay plan from modeling?
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 30 June 2021 - 08:20 AM
I want a faded underlay to show up of the first floor on my second floor plan.
I copied the first floor into my second floor file and and faded it.
When I go to 3d view, it models the first floor inside my second floor.
What can I do?
#2 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 30 June 2021 - 09:24 AM
There is an overlay option.
File-Overlay-choose drawing to overlay. When finished hit overlay again to turn it off.
#3 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 30 June 2021 - 10:02 AM
It seems to come in off to the side.  How do I move the overlay?
#4 David Zawadzki
  • 658 posts
Posted 30 June 2021 - 10:12 AM
Did you place a reference mark yet?
  • 5,098 posts
Posted 30 June 2021 - 10:22 AM
Use a reference point on both plans. The circular reference point has some particular properties that are useful. See this post ... http://softplan.com/...ouse/#entry5596
  • Rick Kingsbury likes this
  • 5,098 posts
Posted 30 June 2021 - 10:27 AM
If you drew your first floor plan on a layer on your second floor plan, you can easily delete it. If not then you will probably have to delete each item separately ... or go into each item and remove from model, although there are some items you can't remove from model.
As a general rule, ONLY use one floor plan on each drawing.
As David said, you should use the OVERLAY feature to do what you wanted. The reference points will ensure everything lines up correctly.
  • Rick Kingsbury and David Zawadzki like this
