How to make building outline only reference foundation outline?
Building outline
#1 Jonathan Verduzco
Jonathan Verduzco
  • 43 posts
  • LocationCorpus Christi, TX
Posted 02 July 2021 - 11:09 PM
Hello everyone,
How do you make a building outline only reference foundation outline not the exterior facade? I want to use the copy of the outline to add to the site plan to show along with roof outline.
  • 4,567 posts
Posted 03 July 2021 - 05:57 AM
Overlay the foundation onto the site plan and then trace (SKETCH) BUILDING OUTLINE round the perimeter.
Use Reference Points to ensure everything lines up correctly.
#3 Richard Rubinski
  • 372 posts
Posted 03 July 2021 - 08:26 AM
What type of foundation are you using stem wall, monolithic? You can generate a building outline then offset the building outline in the thickness of your exterior wall material. Then erase the outside building line.
#4 Sam Morgan
  • 578 posts
Posted 03 July 2021 - 10:28 AM
Generate your building outline from the foundation drawing, not the main floor drawing
  • John Jones, Paul James, Thomas Parker and 1 other like this
#5 Jonathan Verduzco
Jonathan Verduzco
  • 43 posts
Posted 03 July 2021 - 10:54 AM
That’s it!!! I’ll try that. I was doing it by the floor plan and it was pickup up the facade. But that sounds like a good idea to generate using foundation. Thanks
#6 Jonathan Verduzco
Jonathan Verduzco
  • 43 posts
Posted 03 July 2021 - 10:55 AM
Monolithic. I didn’t know you could offset building outline, I’ll try that thanks!
#7 Richard Rubinski
  • 372 posts
Posted 03 July 2021 - 11:56 AM
If you have Brick on the front and return say 2' on each side you can explode it then straighten out the brick offset on the side edit it and form a polygon if needed.
