How to make a furred out wall?
#1
Posted 07 July 2021 - 07:24 AM
I was wondering how to go about showing a furred out wall in softplan. In the living room, I want a 2x4 wall furred out 6” which is essentially having a 2x6 wall in front of the 2x4 wall, if that makes sense. This furred out wall will serve to have an electric fireplace. I’ve tried using a custom wall definition but Had some complications making it look good in 3D mode and on the drawing. I don’t know if there is an easier way. Thank you all in advance for your time.
Posted 07 July 2021 - 08:34 AM
If it is furred only for a segment of the wall behind, then best to make it 3 walls that are drawn more like a fireplace chase would be drawn. To keep walls joining properly adjust the wall join tolerances. The return walls may initially have to be drawn longer, then moved into place and adjusted.
- ROBERT BROGAN and Stephan Page like this
Posted 07 July 2021 - 09:05 AM
At times i use a furring wall by the tub. Strange things happen with join tolerance so I have to reduce down to 1/2" then all is fine.
You can create a new thicker wall then add a 'none' line at the correct spot to simulate where your furring occurs. (third image)..watch the join tolerance, might have issues connecting properly.
sorry my explanation might be terrible.
- Steven Wohlgemuth, Allen McDonnell, ROBERT BROGAN and 1 other like this
Posted 07 July 2021 - 01:18 PM
Understood, thanks for this suggestion Mark!
#5
Posted 07 July 2021 - 01:19 PM
Oh okay I can try this also. Thanks for the suggestion Joseph!!!
#6
Posted 07 July 2021 - 06:51 PM
I'd actually design a wall that has two sets of studs. Not sure why it wouldn't work in the 3D. Draw it like you'd build it
- Rick Kingsbury, Mike Adams, Allen McDonnell and 2 others like this
Posted 08 July 2021 - 11:05 AM
It'd be nice if we could have a wall with 2 sets of studs and stop the inner (furred) set at a certain point and end cap it with whatever finishes we want, but that doesn't typically work well. So, I use 3 walls with drywall or finishes on the interior side and adjust them to fit up against the main wall to create the "chase" or furred section as needed. Of course, technically you wouldn't have interior finishes on the wall where that furred section is either. So, then do you cut the wall behind into sections so you can use a definition without interior finishes where furred? Or, go back to Keith's method of a double wall for just that section, plus at finishes to the ends of the furred part? It becomes a bit of work to get the look and representation one wants depending on what the need is. If for rendering it can be way simplified. If for accuracy of a build, it leaves something off or includes some work-arounds to get it showing and representing correctly. Lots of ways to do it, just gotta figure out what works best for you and your project.
#8
Posted 08 July 2021 - 03:53 PM
Yes I tried Making a wall definition and couldn’t finish off the ends and it also didn’t look great for the blueprint. At that time, I just went with drawing a box the thickness of the stud and inserting the fireplace into it to give it a cleaner representation for the blueprint. In the future I want to work with 3D renderings and was wondering if there was an easier way.
