Draw and edit lines in roof mode
14 replies to this topic
#1 John Mayfield
John Mayfield
  • 5 posts
Posted 17 July 2021 - 08:05 PM
New user. After drawing a line in roof mode is there a way to edit it (move, trim and etc) in that mode or any other mode besides draw mode? A bit frustrated. John
#2 Fred Russell
Fred Russell
  • 786 posts
Posted 18 July 2021 - 06:17 AM
Don't think there is a way to draw a "line " in roof mode. Without giving it much thought, I don't think you can draw a line in any mode but "drawing" mode.
Most everything is an object, like "roof outline"
Guess question would be , what are you trying to accomplish.
Understanding the program like anything is maybe a little frustrating at first.
For me it made sense that drawing a wall for instance, you are drawing a 3D wall, which is an object, not lines.
So like the roof lines, aren't lines, they are hips, ridges, eaves, etc.
#3 Henry Buckner
Henry Buckner
  • 342 posts
Posted 18 July 2021 - 06:25 AM
Press "L" to  draw a line in roof mode.
#4 Mark Petri
  • 1,874 posts
Posted 19 July 2021 - 10:04 AM
Or edit your setup in each mode you want to show shapes in the tool bar. Some limitations on the editing once drawn in roof mode though.
#5 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 19 November 2021 - 06:40 AM
I have the same problem. I like to draw arrows on the roof plan to help the truss company design the trusses. First I need to make shapes visible in options/visible items, and this allows me to draw arrows. However, after the arrow is drawn it can't be moved except for going back to drawing mode and moving it from there. It is frustrating because they need to line up with certain text that I placed in roof mode and it becomes a guessing game of switching back and forth and trying to get everything to line up.
  • Joseph Smith likes this
#6 Mark Petri
  • 1,874 posts
Posted 19 November 2021 - 09:40 AM
Wendall,
If attached to text use pointer from the notes tab instead of arrows (you also can add the shortcut to your toolbar or a keyboard shortcut). Also, if concerned about what shows up where, set a layer for ROOF ONLY or something like that and put anything you use in roof mode on that layer to keep it from showing up elsewhere by accident. Not all things will, but it allows for better control sometimes. Also, then you can activate that layer in other modes for easy editing of parts in roof mode that do not play well.
#7 Joseph Smith
  • 853 posts
Posted 19 November 2021 - 09:41 AM
John & Wendall, arrows and Spline arrows could prove to be handy in roof plan mode, maybe even all the basic cad commands.  Make a suggestion, they're usually pretty responsive to suggestions.
#8 Philip Frank
  • 578 posts
Posted 19 November 2021 - 11:50 AM
Make a symbol that contains the arrow you need. Place the symbol in Roof mode. Once placed you can move or rotate the symbol in Roof mode.
  • Wendall Hilty likes this
#9 Keith Almond
  • 5,310 posts
Posted 19 November 2021 - 12:19 PM
You can manipulate drawing items in ROOF MODE, by right clicking and ADD SELECTION them you can right click again and MOVE, EDIT, COPY etc.
  • Jim Johnson and Wendall Hilty like this
#10 Fred Russell
Fred Russell
  • 786 posts
Posted 20 November 2021 - 11:58 AM
Seems the problem with doing lines on the roof mode is that they also show on the drawing mode, from what I can see, is there a way around that, so when you just want a line on the roof mode ?
#11 Gary McKeon
  • 642 posts
Posted 21 November 2021 - 09:41 AM
Custom layer
#12 Mike Adams
Mike Adams
  • 278 posts
Posted 21 November 2021 - 02:05 PM
I use the Birds Eye view for information your speaking about.
On that page I show the field frame areas, pitch, slope, down spout locations for one county, crickets, overhangs, gable set backs, heel heights, chimneys, reverse gable info., cupolos etc.
#13 Dennis Asher
Dennis Asher
  • 247 posts
Posted 22 November 2021 - 10:55 AM
The best way I've found is to turn on visibility of the roof outline, framing, etc. while you are in drawing mode.  As stated above all the annotations, arrows, etc. that you add should be on a layer that is only visible while in roof mode.  Once you're done just turn off visibility of the roof items and custom layer.  You would also have to edit visibility while in roof mode for the custom layer to show.  I suppose you could also make a custom drawing mode but I haven't taken the time to do that.
#14 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 15 January 2022 - 09:09 PM
Keith's solution is exactly what I was looking for. Right clicking on the item and ADD SELECTION allows you to move it at will. Once the item is in place you need to right click again and CLEAR SELECTION.
#15 Keith Almond
  • 5,310 posts
Posted 16 January 2022 - 10:22 AM
You can also use ESC to clear the selection.
