When I create a new wall in system option, it does not show up in my project.
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 27 July 2021 - 02:29 PM
What do I need to do?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 27 July 2021 - 02:50 PM
You can create it in drawing options and it will show up then, but a better way is to export the wall to file in system options. That way you can import it into
any project or drawing you choose.
#3 Fred Russell
Fred Russell
  • 611 posts
Posted 27 July 2021 - 08:58 PM
Go to  Project options at bottom of File roll down. then select "define wall". then at top it will show "reset to system" this will change the project wall to whatever is in the System definitions.
Then you need to do the file roll down and select drawing options and then select "define walls" again, and you will see Reset to project, and hit that if you want to pull that system wall definitions, down to the drawing level.
