Why won't repeat edit work?
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 28 July 2021 - 01:13 PM
I am trying to take corner board off of my entire project.
I click al wall, take or corner board.  Now I click the next wall, and hit repeat edit, but nothin happens.
Is there also a way I could highlight all walls and adjust corner boards this way?
When I do this the property panel goes away.
Thank you
#2 Joseph Smith
  • 824 posts
Posted 28 July 2021 - 01:16 PM
U/D/L/R are important when doing your repeat edit with wall corners.  i'd find a wall to remove both L/R at the same time then do repeat edit.
Posted 28 July 2021 - 01:26 PM
Alternately, right click a wall ADD TYPE (or GROUP) SELECTION then right click and edit the corner trims to NONE
#4 Richard Rubinski
  • 610 posts
Posted 28 July 2021 - 02:12 PM
Do all of the vertical walls and then edit a horizontal wall, then repeat edit the other horizontal walls. As Joseph said.
#5 Sam Morgan
  • 851 posts
Posted 28 July 2021 - 05:20 PM
You need to edit the first wall, THEN click repeat edit, then click the next wall.  It sounded from your original description that you were doing it backwards
#6 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 29 July 2021 - 09:50 AM
Thank you this worked
