Everything new that I am drawing is coming in as grey. They are on the same layer as things that are not grey that
I had previously drawn. Nothing is set to faded, nothing is set to the color grey.
How can I get things to stop coming in grey?
Posted 10 August 2021 - 09:51 AM
Could be your project pens or layers settings that might be causing you problems.
A print a screen or two attached here would help folks identify things for you....'use windows snipping tool'
Posted 10 August 2021 - 11:21 AM
more reply options (below right)/choose file/attach this file
oh ya, dont forget to save your snipping image to your desktop for easy retrieval (my method above)
Posted 10 August 2021 - 01:55 PM
To upload a picture you must first load it, then click to add it (kind of a confirmation of loading the picture). Then post your reply. It sounds like you may have a layer setting or building option setting messing with the windows. If you don't have something changed in the layer or building option you are drawing those openings on, maybe check and see if there is something in the opening definition that is causing it.
