How do I change a wall height without the floor above changing height?
#1 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 26 August 2021 - 02:08 PM
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 26 August 2021 - 02:15 PM
Isn't that what would happen in real life?
#3 Martin Livingston
  • 694 posts
Posted 26 August 2021 - 02:56 PM
Once you add the circle reference point to each floor in the model Softplan sets the zero mark for the next floor to the top of the wall the reference point is attached to. You can change the height of any other wall without moving the floor above it.
  • Andrew Morrison likes this
#4 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 30 August 2021 - 06:50 AM
Thank you Martin! How do I go about adding said circle reference point? (As my profile has diagnosed, I am indeed a newbie.)
#5 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 30 August 2021 - 06:53 AM
Never mind, just stumbled through how to do it. Thank you!
#6 Joseph Smith
  • 824 posts
Posted 30 August 2021 - 01:38 PM
At each model drawing I add a wall segment with the common location, correct height per designed level, hidden and deselect extract in model.  Now you can change any house wall as you see fit w/o the worry of effecting the model stack of your designed levels.  Remember this wall is not associated to anything other then the reference point for setting up the x,y,z location of each level.
This works the exceptionally well with bi/tri-levels or anything with levels happening allover the place.
Learned this with Vertex BD years ago
  • Mark Petri and Andrew Morrison like this
#7 Fred Dickson
Fred Dickson
  • 209 posts
Posted 31 August 2021 - 04:55 PM
Thank you Mr. Smith!  What a great work around!!!
  • Joseph Smith likes this
