I'm looking to add things lik spot elevation symbols, elevation tag symbol ect.
Is there a place where I can find and add these into my drawing?
Posted 31 December 2021 - 06:27 AM
Great question, because I am a new SP user and (migrating over from Chief Architect) I thought things like framing references and level lines would come pre drawn with package. So in this respect Chief Architect is light years ahead of Softplan. But, you can create your own symbols, and I created them for elevation references shown in 2D, like the framing reference for the 1st floor sub-floor as being 0'-11 1/2" along with a framing reference marker to go with it.
But...
After I saved the symbol(s), every time I go to place them half of the text disappears. Its been two days now trying to get an answer from technical support as to why this happens. Everything shows up in the library preview, and everything shows up on the first placement click of the mouse. But after the second mouse click to set the orientation, a dialog box comes up. At this point the symbol is still intact. As soon as the dialog box is closed, all of the text above the horizontal line of the marker disappears.
Lane De Muro
Windows 10 on a Dell something or other which works but should be replaced.
Posted 31 December 2021 - 09:19 AM
Did you set ATTRIBUTES for the text?
Posted 31 December 2021 - 10:33 AM
But...
Posted 31 December 2021 - 03:28 PM
Can you snag and post some examples of what you are having trouble with? I am not quite sure what you are having trouble with... if you are in annotated mode, aren't the "level lines" generated automatically?
I will look into that. I thought the datum markers were only generated in Elevation Views, not plan views.
Thanks.
Lane De Muro
Posted 03 January 2022 - 05:28 PM
I did this with a plan I am just starting to work out. I can easily add my elevation marker and notes. Make sure you have the elevation showing in annotated view. Look near the top of my screenshot and you'll see it highlighted.
