Thickened Edge Slab
#1 Dan Campion
Dan Campion
  • 11 posts
Posted 10 September 2021 - 08:07 AM
How can I get the foundation to show like the attached cad drawing with a thickened edge slab and a sloped edge where it meets the floor?  All I can get is a rectangular grade beam.   The techs have told me that it's not possible.  Seems like this is a standard construction detail and there should be a way??
#2 Mark Petri
  • 1,874 posts
Posted 10 September 2021 - 09:19 AM
Unfortunately you cannot do it with a slab. The best way I've found is to create a wall that has the correct profile and then set it so the slab is just over it or lined up how you want it. The section will show the lines between the slab and wall, but you can either manipulate the SV settings or just save the 2D section and clean up lines. An alternative I've used if I want total control is to build the foundation in SketchUp and import it as a symbol to SP. Another area where it would be nice if we had more control of how footings/slabs/foundations behave.
#3 ROBERT BROGAN
ROBERT BROGAN
  • 52 posts
Posted 11 September 2021 - 05:01 AM
in "floor system"
1. draw a slab
2. edit the slab.
3.  change from 'non structural' TO 'structural'
4.  edit slab, edges, etc.
Hope this Helps
Bob.
Posted 11 September 2021 - 07:14 AM
That ONLY works for an 8" depth. The 45° angle is ONLY ever drawn at 4", so doing anything else, results in a rectangular grade beam as Dan said in the first post.
  • Dan Campion likes this
2 user(s) are reading this topic
    Google (1)
