Why won't my wall show in other view (not a layer problem)
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 13 September 2021 - 02:39 PM
I created a new wall,     it shows in plan, and section cuts, but not in 3d model.
Any idea why?
#2 Heath Foster
Heath Foster
  • 177 posts
Posted 13 September 2021 - 05:16 PM
A couple of Ideas,
Check the height/offset
Is the wall being extracted into the 3d model (framing doesn’t show by default)
There is a check box on the common tab for the wall that must be checked. Something like extract in model.
When you edit the wall definition the same checkbox is found in the options. It may be unchecked.
#3 Mark Petri
  • 1,874 posts
Posted 13 September 2021 - 05:18 PM
Also, if you are using uncommon materials, they may not be set to be displayed in 3D, so be sure to check the materials list to see if they are checked to display.
Posted 13 September 2021 - 06:11 PM
A few of the materials (for example RIGID INSULATION) do NOT show in the 3D.
Can you post your wall definition (or Screenshots of it) here?
#5 Fred Russell
Fred Russell
  • 789 posts
Posted 13 September 2021 - 06:37 PM
I think i just ran into that today, and as Mark said, in the material Texture edit, the walls and materials of the walls might be turned off.
My issue was that I had the drywall turned off.
#6 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 14 September 2021 - 07:48 AM
I had my drywall set as fibreboard,  turning it to drywall worked.
