I have some lines that I drew that I cannot delete.
7 replies to this topic
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 16 September 2021 - 11:12 AM
I have some lines that I drew that I cannot delete, I drew them on my roof plan,  they are not on
a locked letter.
Ay ideas?
#2 Gary McKeon
  • 642 posts
Posted 16 September 2021 - 11:44 AM
Go back to your 'drawing' mode and you will see them there to delete
#3 Joseph Smith
  • 853 posts
Posted 16 September 2021 - 12:40 PM
Yep
#4 Jon Davis
Jon Davis
  • 543 posts
Posted 16 September 2021 - 03:44 PM
That's one thing I wish SP would fix
  • 5,311 posts
Posted 16 September 2021 - 05:00 PM
You can RIGHT CLICK it ADD TO SELECTION, then RIGHT CLICK and ERASE.
  • 5,311 posts
Posted 16 September 2021 - 05:02 PM
I would like to be able to MOVE objects between MODES
  • Jon Davis likes this
#7 Jon Davis
Jon Davis
  • 543 posts
Posted 17 September 2021 - 07:14 AM
I think the thing about it that aggravates me the most, is if I want to use a little line work on the ceiling joist plan or roof plan for some reason, then all my line work on the floor plan has to be on a separate layer, or else when you turn on line work in CJ or Roof, then ALL line work shows up. And to be able to move or edit lines you Drew on the CJ plan, you have to go Back to the Floor plan, turn on the CJ layer, and then edit your line work.
  • Keith Almond and Gary McKeon like this
#8 Mark Petri
  • 1,874 posts
Posted 17 September 2021 - 09:30 AM
I have layers set up for the odd lines, text, dimensions and symbols I only want showing in floor, roof, or ceiling mode so I can draw on that layer while in the respective mode or, better yet, use a custom mode to turn on what I want and edit there. I am trying not to save 2D line drawings of framing plans as it seems they always change and then I am going back to clean them up again and again. So, using layers set for the things I want on each mode and then using custom drawing modes helps. Also, an occasional building option for custom visibility helps.
  • Jon Davis and David Zawadzki like this
