Show Opening Trim Lines On Prints
10 replies to this topic
#1 David Johnson
David Johnson
  • 74 posts
  • LocationSioux Falls, SD
Posted 28 October 2021 - 11:40 AM
This may have been addressed before; I did a quick search through the forums but did not find what I was looking for. Is there a way to get the opening trim lines to actually print? For example, when you turn on trim in the drawing, it defaults to show as a red dashed line. However, on the sheet sets and when printing, these lines are not visible and do not print. I have gone through system settings and played around with different options in an attempt to make it work, but I cannot seem to find the correct one. Does anyone know how to make this work?
#2 David Zawadzki
  • 663 posts
Posted 28 October 2021 - 12:35 PM
Why do you need that?
#3 David Johnson
David Johnson
  • 74 posts
Posted 28 October 2021 - 12:54 PM
My boss wants to be able to show the widths of the door times, especially since we tend to use very wide custom trims on a regular basis. Seeing it on printed plan sets will also allow the customers to have some kind of visual to see how close trim pieces get to the corners, cabinets, etc...
#4 Richard Rubinski
  • 611 posts
Posted 28 October 2021 - 03:18 PM
This is my cheat sheet using RB3 Trim.
#5 David Johnson
David Johnson
  • 74 posts
Posted 28 October 2021 - 03:42 PM
It's really more of a visual thing, not a verification of clearances thing. It's just one of those details that would be nice to show on the plans if possible, although it seems to not be an option at this time.
#6 Gary Wicklund
Gary Wicklund
  • 162 posts
  • LocationDuncan BC Canada
Posted 29 October 2021 - 08:00 AM
Did you check the visible items list?
You may need to draw a dashed box over the red dashed box, shouldn’t take too long to do?
#7 Richard Rubinski
  • 611 posts
Posted 29 October 2021 - 09:17 AM
You could make a detail showing that you have enough room for wider trim.
#8 Mark Petri
  • 1,512 posts
Posted 29 October 2021 - 11:57 AM
Or, you could make up a group of boxes or polygons saved as a symbol for the different trim and door sizes you use and place it on the plans.
#9 Charles Vienne
Charles Vienne
  • 1 posts
Posted 30 October 2021 - 12:43 PM
David,
I am still using a much older version, but have you tried:
File > > > > Drawing Options > > > > Material Options > > > > Opening Options > > > >Sill:
Sill Thickness
Sill Overhang
Obviously you would have to make door sill(s) visible and of course it only displays on one side.
But possibly that would suffice at least for now.
Charlie
Edited: to add image
#10 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 01 November 2021 - 04:02 AM
dave what i have bin doing is add a line on each side of the trim and set the size of the trim out to out
#11 Jon Davis
Jon Davis
  • 541 posts
Posted 02 November 2021 - 07:48 AM
I know you can turn them on and off visually in the drawing, but as others have mentioned I've yet to find a way to make them print. I have set them to the correct size though, so that when placing doors near corners or two doors close to each other, I can visually tell if there's room enough for the trim.
