See attached File.
How do I correct this? I created a window with no glass for the arched trim.
Posted 10 November 2021 - 12:35 PM
Bryan,
Is your arched opening above the actual window only as tall as the space it occupies above the window? If so, that may be the issue. Try making it taller and turn off visibility of anything below the top of the window. Also, I think you may do better just using the deflection option on the exterior trim menu for the arched rowlock instead of trying to do what you are with an arch. But, there are many ways to accomplish what you are trying.
