Arched Trim on Window -- Soldier Course Issue
7 replies to this topic
#1 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 10 November 2021 - 10:27 AM
See attached File.
How do I correct this? I created a window with no glass for the arched trim.
#2 Richard Rubinski
  • 604 posts
Posted 10 November 2021 - 11:00 AM
Even though you don't have any Side Trim decrease the widht. Hope this helps. Use the Display Tab for the Window Sill.
  • Attached File  Trim.JPG   323.35KB   0 downloads
#3 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 10 November 2021 - 11:13 AM
Thanks, Richard.
I did have the sides set @ 0 and tries setting it @ .01. Still no luck.
#4 Richard Rubinski
  • 604 posts
Posted 10 November 2021 - 12:03 PM
Look at my screenshot and set your settings are set to what I have.
#5 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 10 November 2021 - 12:24 PM
Thanks, Richard.
Same result.
#6 Richard Rubinski
  • 604 posts
Posted 10 November 2021 - 12:34 PM
Is your arch above the window attached to the window? What is arch above it?
#7 Mark Petri
  • 1,506 posts
Posted 10 November 2021 - 12:35 PM
Bryan,
Is your arched opening above the actual window only as tall as the space it occupies above the window? If so, that may be the issue. Try making it taller and turn off visibility of anything below the top of the window. Also, I think you may do better just using the deflection option on the exterior trim menu for the arched rowlock instead of trying to do what you are with an arch. But, there are many ways to accomplish what you are trying.
#8 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 10 November 2021 - 02:26 PM
Mark - That works!
Richard - Thanks for your help.
  • Mark Petri likes this
