siding options vertical
Siding
12 replies to this topic
#1 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 21 November 2021 - 03:15 PM
I'm trying to create a vertical b and b siding
right now its a bunch of close lines.
using edit/edit surface i now have a tab that shows texture color/lighting/options
using options my preview looks like i want
Distance is my problem,
my wall is 10 ft tall, siding should be 8" vertical
how do i know what to use for Horizontal and vertical?
 i would think that horizontal would be 10' and vertical would be 8" that doesn't fix my problem
the Maintain Aspect Ratio- where does this come into play?
Thank you
Posted 21 November 2021 - 03:33 PM
If you're creating a board and batten texture, rather than a wall, then Softplan Uses 16 pixels per inch (1 pixel = 1/16 inch) so you can design the pixel size of your texture accordingly.
#3 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 22 November 2021 - 07:51 AM
Keith, that is like a binary number thing, i don't get it?
under surface edit options distance i need a number for horizontal and vertical.
wall is 10 ft tall and so is siding
siding board and batten is in 8" widths
how do i make the 1/16" pixel formula
 the next box of choice is "Maintain aspect ratio"  when do i use or not use this option?
thank you
#4 Joseph Smith
  • 824 posts
Posted 22 November 2021 - 09:00 AM
i think of it in terms of what is the 'display texture' showing.
for example here is a chunk of b/b with a horiz distance of 1'-0".  in 3d or model view it appears to be 12"
I don't understand the pixel stuff either.
Great b/b selection in Cedar Creek textures
Posted 22 November 2021 - 12:12 PM
Just to be clear, what exactly are you trying to create.
#6 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 22 November 2021 - 01:08 PM
I used a wall from SP 2022 2x4 Board and Batten,
i tried to edit the surface with certain teed color that is in my selections.
im just trying to get a certain teed siding color as a 8" vertical B and B look in mountain cedar.
I dont really know what im doing :{
Joe smith has a thumbnail picture of cedar creek siding. Im assuming he imported that in. How?
#7 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 22 November 2021 - 01:28 PM
I found the library that Joseph Smith referenced. Thank you
im waiting on SP support to somehow explain to me how to know what the dimensions are to be used in surface options /Distance of Horizontal and vertical
Thank you
#8 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 22 November 2021 - 02:06 PM
Steve V. i noticed you might be reviewing. this can be looked at SP support ticket numbers 74313 and 74334.
If there is any video or online webinar to watch on how to do some of this i would be very appreciate to know where i can find them and watch it a few times.
basically i dont know what im doing.
Thank you
#9 Keith Almond
Posted 23 November 2021 - 12:19 PM
You don't generally need to set both height and width as the textures are normally seamless and repeat to suit. If you have a texture that only shows one batten, then set it as 8" horizontal (2 =16", 3=24" etc. Normally you wouldn't want to stretch a texture disproportionately, so you would almost always check "Maintain Aspect Ratio" and edit one dimension to suit, to resize the whole texture.
What I was saying about pixels earlier, if you have downloaded any (seamless) texture from the internet, say it shows 4 horizontal battens and 4 boards, and you therefore want that texture to be 32" wide (4 x 8" spacing) then that particular texture will have to be 512 pixels wide (or have to be resized as a jpg to 512 pixels wide) - 32" x 16 pixels/inch
You can normally calculate how wide you want the texture to show, based on what the texture itself shows - for example if you want this texture:
Attached File  Annapolis Blue.jpg   32.19KB   2 downloads
to have battens at 8" o.c. then it would be set at 32" wide ... and indeed, I designed it to be 32" wide ... so 512 pixels.
Attached File  2021.11.23_13h17m09s_001_.png   18.55KB   1 downloads
As a general rule, you wouldn't want to change any of the texture sizes - They SHOULD be correct as they were designed - unless they are obvioulsy wrong.
Does any of this make sense now?
#10 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 24 November 2021 - 10:00 AM
Keith, that helps a lot.
SP support , Jacob and i just confirmed that my image i was copying was too small and was including the box around the sample color from Certainteed. I agreed. Problem resolved and between you and SP support Jacob i have learned a few things regarding copying and creating.
Looking at your thumbnail of the pixels, i've never seen that option box. Once i find that the pixel example will definitely make sense to me. :)
Thank you Keith.
#11 Keith Almond
Posted 24 November 2021 - 10:08 AM
That box is a Windows box - go to any image in WINDOWS EXPLORER - C:\SoftPlan\3D\Textures\Bitmaps etc. - right click and go to PROPERTIES > DETAILS
#12 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 24 November 2021 - 10:35 AM
Keith,
i found a larger sample on google image of my siding ans the color i want. i copied and saved. I found the pixel box you shared. It does not allow me to change the pxel, where or waht do i do to adjust the pixel?
#13 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 24 November 2021 - 10:41 AM
Keith, i found the resize pixel box. done. thank you again
Also tagged with one or more of these keywords: Siding
