Posted 06 December 2021 - 09:46 AM
Where should these show up? I cannot dimension anything on the Floor System mode.
I have the dimension settings on to go to the edge of footing.
Posted 06 December 2021 - 10:58 AM
Add them in drawing mode. You can put them on a layer if you want to have them show up on other modes.
Posted 06 December 2021 - 01:11 PM
While you are in Floor System Mode use Options > Visible Items and turn on Wall Footings (from drawing Items) you can add extensions and dimension them. You can also use diagonal square.
Posted 06 December 2021 - 04:47 PM
I saw on Extension format yesterday, where it can be extension edge, or none for foortings and the same for slab footer
And deminsion format the same, maybe that is the problem
