Spiral Staircase
28 replies to this topic
#21 Anthony Wielemaker
Anthony Wielemaker
  • 75 posts
  • LocationGreely, Ontario
Posted 09 September 2015 - 01:04 PM
Ha Ha Steve I've kind of hyjacked your thread, sorry.
That's very interesting Yvon, where are these pics from, are these available in Ontario?  This info will be helpful in the future.  Nothing worse than telling a client they can't have something because it doesn't meet code only to have them come back to with a version that is acceptable.
#22 Yvon Gonthier
Posted 09 September 2015 - 01:15 PM
http://stairkit.com/.../spiral-stairs/ from BC or http://www.spiralsta...l-staircase-kit Toronto but seems to be same as BC
#23 Steven Kirchoff
Steven Kirchoff
  • 113 posts
Posted 09 September 2015 - 01:17 PM
OK, how do you get the rail and spindles to follow the treads?
#24 Anthony Wielemaker
Anthony Wielemaker
  • 75 posts
Posted 09 September 2015 - 01:20 PM
Pick outside railing and then  pick the railing in 3D to modify to suit.
Thanks Yvon hopefully I can find this bookmark when I need it.
  • Yvon Gonthier likes this
#25 Yvon Gonthier
Posted 09 September 2015 - 01:34 PM
#26 Keith Almond
Posted 14 September 2015 - 07:20 AM
Anthony, that colour phenomenon happens regularly to me too - but ONLY on spindles. SURFACE COPY/PASTE doesn't seem to work. As you say the only thing that seems to work is exit and reload.
It appears that going to the COMMON tab, and pressing PERFORM ITEM CLEANUP will fix it too.
#27 Anthony Wielemaker
Anthony Wielemaker
  • 75 posts
Posted 14 September 2015 - 11:17 AM
Well that would be a quicker fix, Thanks Keith I'll give it go next time...if I remember.
#28 randolph cohn
Posted 14 September 2015 - 12:40 PM
you can go into
system options / finishing options / railing options
and rename the railing with a color that you'll have to put on
a railing.  once their set,
you can change the railing finish on your drawing to
a number with a color in the name.
like -  railing 6 - white
i can't remember the exact procedure.  i did it a while ago
and it is a little confusing but once you do one,  you'll get the idea.
#29 Anthony Wielemaker
Anthony Wielemaker
  • 75 posts
Posted 14 September 2015 - 12:46 PM
Thanks Randy I've done that with areas before too and had it nicely set up and then the next version of softplan came along and wiped it out so I never redid the set up.  With the new update procedure, which worked super slick, maybe I'll start that type of customization again and it won't get wiped out. This was really a problem with the surface colour or texture not updating properly.
