Searching this site seems to suck so creating another post. I accidentally bent my key with sticking out of the PC. It still works but i had to mess with the metal plug with pliers to get it in and out. How does SP handle getting a replacement key?
Posted 12 October 2015 - 02:14 PM
Joseph;
It has been awhile since I have had to replace a key. I assume the procedure is the same and probably is on the website somewhere. You will need to call Softplan and tell them you to need to replace your key. They will send a new one out right away and then you have so many days to return your old key to them. Be sure and send with tracking and enough insurance to cover a lost package. Once SP receives your key then everything is ok. If SP does not receive your key to them they will charge you for a new one as if you were purchasing a another key; that is why you insure for the amount of the replacement key if that would become necessary.
Kevin
Posted 13 October 2015 - 06:59 AM
A replacement key can be ordered at:
https://softplan.com/?page_id=788
If you're replacing a key from a recent version it's a straightforward process, no tracking or insurance required.
Posted 19 October 2015 - 09:26 AM
https://softplan.com...=k&page_id=1041
Im not seeing where I could order a replacement key on that page. I don't need one now, but since I only have one key I've often wondered how bad I'd be screwed if I lost my key or it broke it when I was nearing a deadine on a project.
If I lost my key today, how long would it take for me to be up and running again with a new key? Is there a way Softplan could give me temporary access to run the software until my new key arrived? I work from several different PCs and my key stays on my keychain with me at all times. It's just a matter or time before it breaks.
#5
Posted 19 October 2015 - 09:41 AM
SoftPlan must have a key to run.
If a key is lost please select replace on this page https://softplan.com/?page_id=788.
If you think a key is failing please contact technical support so they can try to diagnose any issues.
#8
Posted 19 October 2015 - 12:27 PM
Thanks for the link John. Looks like we can be up and running pretty quickly with after busting a key......just don't delay in mailing in the broke one!
Also tagged with one or more of these keywords: key
SoftPlan →
SoftPlan version 2020 →
"Esc" key does not cancel the dimension commandStarted by Tom McConnell , 25 Sep 2019 Esc, key, cancel, dimension |
SoftPlan →
SoftPlan 2018 →
The Surface Book, The Key, and Every Problem In BetweenStarted by Dustin Hollingshead , 09 Feb 2019 4k, Surface Book, Key, Tablet and 2 more... |
SoftPlan →
SoftPlan 2016 →
key not workingStarted by Thomas Davis , 09 Nov 2015 softplan key, key and 1 more... |
