Exterior mouldings around beams
9 replies to this topic
#1 Shane Vanbarneveld
Shane Vanbarneveld
  • 1 posts
Posted 28 January 2015 - 02:32 PM
How do you add exterior crown mouldings onto beams?
#2 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 28 January 2015 - 03:13 PM
All moldings are generally added in the Interior drawing mode
It is also possible to add them using the profile tool in Softview (3d mode)
-Chris
#3 Todd Williard
Todd Williard
  • 230 posts
  • LocationPA
Posted 29 January 2015 - 02:42 PM
 I'm not sure how to add images here but I often create walls to be used as beams. I then create the profile of the moldings and include it in my wall assembly.
V11-V2024
Posted 29 January 2015 - 03:41 PM
Todd, Why would you create a wall to be used as a beam ..... Why don't you just create a beam? (Not criticising, just querying ... There's usually more than one way to do work arounds). Beams work much better than walls with the posts!
#5 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 29 January 2015 - 04:03 PM
Moldings will not generate on Beams so you have to use walls instead (unless I have missed some setting)
-Chris
#6 Thomas Roman
Thomas Roman
  • 366 posts
  • LocationSacramento, CA
Posted 29 January 2015 - 05:06 PM
Interesting that INTERIORS mode CROWN will not generate on a BEAM.... BUT an INTERIORS mode BULKHEAD WILL generate on a beam...
so easy enough to add a crown profile (say, "American") to the bulkhead profiles (SYSTEM OPTIONS / FINISHING OPTIONS / BULKHEAD OPTIONS...)
the attached was draw with a "bulkhead".... with "American" profile added to the bulkhead profiles... then edit the generated crown to a larger size...
also note that 2016 will allow one click ADD DRYWALL to beams...
#7 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 29 January 2015 - 05:20 PM
Interesting, I can not get a bulkhead to generate to a beam.
There must be some other factor involved.
-Chris
#8 Todd Williard
Todd Williard
  • 230 posts
  • LocationPA
Posted 30 January 2015 - 09:00 AM
Hi Keith,
I had issues with the moulding not mitering at the corners when added to a beam profile. Also, I got in the habit of using walls for beams to show arches in them. The openings>arch  works well for this.
also as a side note, how to we post images?
V11-V2024
#9 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 30 January 2015 - 09:09 AM
You click "more reply options" at the bottom right corner where you can attach a file
-Chris
#10 Todd Williard
Todd Williard
  • 230 posts
  • LocationPA
Posted 30 January 2015 - 09:32 AM
Thanks Chris
V11-V2024
