how can I draw a set of stairs like this in SP?
#1 Cory Ewing
Cory Ewing
  • 58 posts
Posted 12 November 2015 - 09:02 AM
These stairs don't seem to conform to any of the defaults in Softplan.
Posted 12 November 2015 - 09:30 AM
Use two sets of angled stairs ... and adjust number of stairs to suit ...
Explode the top set, and remove one set of stairs
Press CTRL-C to cleanup, and snap the two sets together.
They will then edit as one full set ...
Adjust to suit
Note --- there is a trick to editing multiple component stairs ... Right click on the section you want to edit (one of the straights or angles), and the individual component will be available on the straight or angled section on the relevant tab on the edit menu.
  • Yvon Gonthier and Cory Ewing like this
#3 Yvon Gonthier
Posted 12 November 2015 - 09:35 AM
Under stairs, you have landing. Use this function to draw your 2 landings. Use sketch straight stairs to draw your 3 stair sections.
Note that you will have to adjust the offset of your landings to the proper height because the stairs will attach to the landings and Softplan will adjust your number of stairs to fit between these heights.
  • Cory Ewing likes this
#4 Cory Ewing
Cory Ewing
  • 58 posts
Posted 12 November 2015 - 10:29 AM
3.5 years of Softplan and it never occurred to me that I could explode stairs and rejoin sections.  That was too easy.  Thanks!!!!!
Posted 12 November 2015 - 02:26 PM
... explode stairs and rejoin sections ...
Obviously only works with multi-component stairs, if you explode a single stair it's GAME OVER.
