barn door help
15 replies to this topic
#1 Matt Orner
Matt Orner
  • 76 posts
  • LocationFargo, ND
Posted 12 November 2015 - 05:23 PM
Hey everyone, I need some help & expertise. How can I create a 6'-0" barn door opening for an interior 3.5" wall. I need two separate 3'-0" door slabs for the opening and I want one running one way and one running the other. I can do a 6'-0" ext. face sliding door but thats just to one side. I have created a couple door openings in the past but nothing like this. Any help will be great.
Thanks in advance
#2 randolph cohn
Posted 12 November 2015 - 08:19 PM
you can get the barn door wheels that slide on the track in sketchup
or you can make them yourself within softplan
with solid cubes and horz cylinder
put the solids together and create a 3d symbol - read up in the HELP
the opening in the wall is created with an "opening / arch / flat"  edit to size
the doors are solid cubes with a old wood texture "SCALED"
note: you can use any texture you want.
click to enlarge
Posted 12 November 2015 - 08:48 PM
Okay ... let's see what we can do.
Completely different methodology to Randy's .....
Go to - SYSTEM LIBRARY > CONFIGURE LIBRARY > OPENINGS and go to FACE SLIDING
CLICK ONE STEP
Give it a suitable name ... 72 x 80 DOUBLE BARN DOOR
CUSTOM OPENING
Type ... FACE SLIDING DOOR
and under Elevation Choose the LIBRARY and SYMBOL that you want to use for the door - You could choose a plain door and then texture it to suit later.
OK
Then under COMPONENT ... Click ADD and add the same door to the right of the one you have
EDIT INDIVIDUAL COMPONENT for the first one:
COMPONENT:
Plan - CHECK - Reverse  (Reverse shows the door on the outside of the wall, typically where barn doors are)
Dimensions:
Width - 36"
Height - 80"
Operation - L
Swing - 90
ELEVATION
Sill - None
Frame - UNCHECK - Right and Bottom
EDIT INDIVIDUAL COMPONENT for the Second one:
COMPONENT:
Dimensions:
Width - 36"
Height - 80"
Operation - R
Swing - 90
ELEVATION
Sill - None
Frame - UNCHECK - Left and Bottom
OK
Go to EDIT ENTIRE OPENING
Make sure Rough Width and Rough Height are what you want.
OK
It doesn't show door tracks, but you can always make a pseudo track with a solid above the door ...
Should work ... Let us know how you get on.
  • Tom Rogers likes this
#4 Todd Williard
Todd Williard
  • 192 posts
  • LocationPA
Posted 13 November 2015 - 08:33 AM
Nice work Keith
V11-V2024
#5 Matt Orner
Matt Orner
  • 76 posts
  • LocationFargo, ND
Posted 14 November 2015 - 12:34 PM
Awesome. Thanks keith. You've helped in the past with door creations.
#6 Matt Orner
Matt Orner
  • 76 posts
  • LocationFargo, ND
Posted 14 November 2015 - 12:39 PM
Actually surprised with all the blocks that softplan have and as popular as barn doors are they don't have something like what you created.
  • Matt Orner likes this
#7 randolph cohn
Posted 14 November 2015 - 03:54 PM
this is a nice surprise and early holiday gift.
super keith.
and you can make them open and closed as with any door.
these sliding barn doors are becoming fairly popular for interiors.
won't have to use my archaic way.
thanks keith for all you do
click to enlarge image.
#8 Ron Mejeur
Ron Mejeur
  • 66 posts
  • LocationKalalmazoo, Mi
Posted 08 March 2016 - 10:43 AM
I set up a colonial door like this.  It shows up as a sliding door on the outside of the wall and open as it should.  I marked it to open 90 degrees, but when I go to 3d the door shows up as closed.  What did I do wrong?
Ron Mejeur
#9 Keith Almond
Posted 08 March 2016 - 11:29 AM
You didn't do anything wrong Ron, The 90° opening is on the plan ... You need to check OPEN IN MODEL on the same tab you had open at 90° on.
#10 Ron Mejeur
Ron Mejeur
  • 66 posts
Posted 08 March 2016 - 12:11 PM
Thanks, Keith.  So simple.  Didn't think of that.
Ron Mejeur
#11 Thomas Davis
Thomas Davis
  • 301 posts
  • LocationOrange Park, Florida
Posted 08 March 2016 - 12:13 PM
If you haven't already, go to this post in "Product Suggestions" and add your comment for including Barn Doors in the SP stock drawing library.
The more comments we have there, the more likely SP will add them.
http://softplan.com/...?hl=+barn +door
#12 Yvon Gonthier
Posted 08 March 2016 - 12:41 PM
In reality, if you really want a chance, you have to send Softplan the suggestion on the Softplan site under Support>Softplan Suggestions. The "Product Suggestions" on this site is only for discussions between us. Softplan says that the developers only work with the suggestions sent to their site. I imagine that if at some point there's a huge amount of suggestions on this site about the same items that the administrators might forward it to development but by that time, it may be taken in consideration in future versions, not the upcoming one.
#13 Ron Mejeur
Ron Mejeur
  • 66 posts
Posted 09 March 2016 - 08:13 AM
I did send in the suggestion to Softplan support.
Ron Mejeur
#14 Matt Orner
Matt Orner
  • 76 posts
  • LocationFargo, ND
Posted 09 March 2016 - 12:31 PM
Me too
#15 Philip Frank
Philip Frank
  • 560 posts
  • LocationMaine, USA
Posted 09 March 2016 - 01:50 PM
Me too
#16 randolph cohn
Posted 31 March 2017 - 09:54 AM
  1. barn doors have been added to 2018 as has been noted.
after a few hiccups,  their working nicely.
thanks SP tech
