Aligning Floors - Link Floors
Align Overlay Link Floors
8 replies to this topic
#1 Brett Harter
Brett Harter
  • 9 posts
Posted 17 November 2015 - 04:33 PM
I am still pretty new to SoftPlan.  I inadvertently shifted the foundation horizontally on a 2 story plan I am working on.
I have tried using reference points, using the Move Block - Link Floors approach, using Move Block  -Select Move Point, etc. and I cannot seem to get these floors lined up again.
Any ideas?  I have spent an afternoon on this.  I would have thought it should have taken seconds.
Thank you for your input.
#2 randolph cohn
Posted 17 November 2015 - 05:47 PM
check to see if you have a "recovery" file of the floor plan "BEFORE" you block moved it.
if you don't and if you can
open up the floor plan you block moved
than go to FILE / OVERLAY
and your other plans will show.
open up the floor plan below or above the one you block moved which is
most similar to the one you moved.
than "move" the walls on your moved floor plan to where they should be.
Posted 17 November 2015 - 07:47 PM
As long as the reference points (use the CIRCULAR ONE), are in the same position on the plan on every floor plan, the model should stack properly. Just DELETE all the reference points and then put new reference points at common locations.
#4 Brett Harter
Brett Harter
  • 9 posts
Posted 17 November 2015 - 08:18 PM
Keith -
Thank you.  I had tried the reference points earlier today but must have been doing something wrong.  This fixed the issue in seconds.
#5 randolph cohn
Posted 18 November 2015 - 07:16 PM
keith is correct when stating that if you put the top (circle w/cross hairs) ref pt
in the same place on each floor, those ref pts will stack on top of each other.
i was explaining how to get the floor plans to stack on top of each other
without having the ref pts which you shouldn't have to do it you
"DON'T"  >  "block move" any floor plans once you've done a "save as" of
the first floor plan you draw and than NAME them.
NOTE: you can BLOCK MOVE the first floor plan your draw anywhere you want as
long as you BLOCK MOVE  "it" in ONE DIRECTION at a time
(meaning:  DON't  > UNlock the cursor when moving).
once you "save as" any other floor plan from that one original,
DON'T "block move" them or the first one either.
if anyone would like to explain why you don't want to block move any of
the floor plans that you save from the first floor plan you drew
or block move the first floor plan you drew once you start saving other floor
plans for that matter.
tip: think of floor systems, roof plans and other components for that matter
and where they'd end up if you start block moving things nilly willy
if you block move them all over the place and you want to MERGE THEM
without the use of ref pts.
trust me.  it's just better to NOT block move. floor plans once you've saved as
from the first floor plan.
btw,
i've speaking more from a "multi-drawing" person kind of guy than a "plan set" person
since I haven't begun to learn plan sets >>>>>  YET
#6 Brett Harter
Brett Harter
  • 9 posts
Posted 19 November 2015 - 10:54 AM
Thanks Randy -
I was Block Moving the floors and, just as you said, it didn't go well.  I made a mess of things.  Using the reference points did work.  As I recall, I originally copied the circular reference point and pasted from drawing to drawing.  That did not work.  Drawing each one individually on each floor solved the problem.
Thanks for the info.
#7 randolph cohn
Posted 19 November 2015 - 11:20 AM
rich,
i also
copy the ref pt from one drawing
and
paste and hold position onto the other drawings
in the floor stack.
this does work.
Posted 19 November 2015 - 11:34 AM
I never have any issues with BLOCK MOVING plans Randy. I do it regularly. In my opinion that's what the reference points are for - And as discussed previously don't use SAVE AS. Obviously whatever works best for us as individuals is the way to go.
I must admit that I don't use copy and paste on the reference points. It's just as quick to put new points on all the drawings.
#9 Yvon Gonthier
Posted 19 November 2015 - 11:35 AM
A thing you have to be careful when you copy and paste is that you must be in Default Building Option and Layer otherwise it will copy on a layer or option and may not be active, so it wouldn't work. Also, I have found that if your Circular reference point is not visible of each level (ex, if "Show Non-Printable Items" is unchecked), then it won't align your floors.
Also tagged with one or more of these keywords: Align, Overlay, Link Floors
