| Adjust of Cabinet Run
Allowed |
| Allow Countertop Property Added
to Symbol |
When seleted, a run of cabinets
will automatically build the symbol into the cabinet run.
| An Exploded Countertop Maintains
a Dashed Line Type |
| When the countertop symbol is exploded,
the countertop maintains its dashed line type on plan. |
| Area Added to Countertop Tab on Edit
Cabinet Dialog |
| Auto Cabinet Placement
Improved |
| Cabinets on Cross Sections Are Saved as
Symbols |
| Cabinets Can Now Have Legs
Added |
Legs can be added to cabinets.
They will be represented in both the elevation and 3D
views.
| Cabinets with Different Heights Show a
Break Line in Plan |
Adjacent base, desk, vanity, and tall
cabinets of differing heights show a break line in plan view.
Countertop Length
Added to Edit Dialog Cabinet |
When editing a
countertop, the edit dialog now provides the length and area
of the countertop for user reference. |
| Countertops Have a Linestyle
Option |
| When editing Countertops, the user can
now specify the type of linestyle that is used to outline the
countertop. |
| Countertops Adjacent to Each Other at
Different Heights Display Overhangs |
| Doors Can Be
Removed |
| The cabinets library now offers a cabinet
style in which doors have already been removed. |
| Join Cabinet Option Added to Edit
Cabinet Run Tab |
By default a run of cabinets is
joined using the Join Cabinet feature. Deselecting this item allows
individual cabinets to maintain their lines and names.
| Microwave Cabinet Added to Wall
Cabinets |
| Name Override Added |
| Outside Corner Cabinets
Added |
| This cabinet type forms an outside
corner. |
| Snap Points Added to Elevation
Cabinets |
| The Snap tool can now be used on
elevation cabinets |
| Top Height Added to the Run Tab on the
Edit Dialog |
| Making changes to the Top Height of a run
of cabinets allows you to position the entire run at the same
time. |
| Top Height Field Option Added
When Placing Cabinets |
During the initial configuring of
a cabinet the Top Height field is available. The Top Height field is
important when setting the height position of the Wall cabinets, and
in generating 3D images of cabinets.
| Top Surface Extracts with a Material
Thickness |
All cabinets that do not have a
countertop or have their countertop turned off on cabinet edit,
receive a top surface with a thickness. This is useful in creating a
bookcase style cabinet.
| Two Drawer Style Cabinets
Added |
| A two drawer style cabinet is now
available in the library of cabinets. |
