SoftPlan One-on-One Online Instruction Request Form Main Key Number: First Name: Last Name: Email: Phone Number: Preferred Date: (mm/dd/yyyy) Preferred Time: (hh:mm) AM/PM EST EST Amount of Time Requested: 30 60 90 120 minutes Recommended Topics of Discussion: Ceiling Mode - How to Create Trey and Vaulted Ceilings Ceiling Mode - How to Create a Barrel Vault Ceiling Drawing Management - Multi Drawing: Assembling and Scaling Drawings Drawing Management - Multi Drawing: Adding a Partial Drawing Drawing Management -Multi Drawing: Use of System Drawings Drawing Management - Building Options: Using and Customizing Drawing Management - Layers: Using and Customizing Drawing Mode - Dimension and Extension Options: General Overview of the Set-up and How They Work Drawing Mode - Speed Notes: How to Create and Use Attributes Drawing Mode - Floors: Use of Reference Points for Aligning Floors Drawing Mode - Walk Out Bay: How to Draw and Dimension Drawing Mode - Change Wall Command: An In-depth Look at What to Consider When Converting Walls from One Plan to Another Floor System Mode - Offsets: How to Use the Level Command to Create Sunken or Raised Rooms Floor System Mode - Joists: How to Control Joist Placement Including Modifying Reference Edge, Staggering Joists, and Print Layout Framing Mode - Overview of Framing Options (e.g. Wall Corners) as well as, How to Add Individual Studs and Span a Single Header of Multiple Openings Library Management - Wall Definition: How to Create a Custom Wall Library Management - Profiles: How to Create the Trim and Wall Definition Library Management - Symbol Wizard: How to Import and Create Symbols from Sketch-upR Library Management - Openings: Defining a Custom Window with Round Top Transom Library Management - Lathe Tool: How to Create Your Own Post or Spindle Patterns Library Management - Libraries: How to Create a Custom Paint Pattern Library Management - Libraries: How to Sort/Rename Libraries Library Management - Libraries: How to Create and Use Assembled Symbols Library Management - Walls: How to Import and Export Wall Lists Printing - How to Set-up Pen Definitions and Assignments reView Mode - How to Utilize reView for Plan reView (Export, Mark-up, and Import Back Into SoftPlan) Roof Mode - Assistance with Any Complex Roof Design Roof Mode - Overview of How Roof Tools Work Roof Mode - How to Use Various Tools, Such as Fillet and Insert Roof Edges to Change the Shape of a Roof Room Mode - How to Create a Custom Room Configuration Including How to Display Room Names and Design Size in Other Modes Site Mode - Site Plan: How to Input a Site Plan Using Surveyors Coordinates Site Mode - Site Plan: How to Input Elevation Points in Order to Create Topography (e.g.Walk-Out Basement) Site Mode - How to Import a CAD File and Convert Those Shapes to Site Lines, as well as, View in 3D SoftList Mode - Take-offs: How to Create, Draw, and Generate a Simple Report SoftList Mode - What Is Needed to Export a Generated Report to Microsoft Excel SoftList Mode - How to Change Lineal Listings of Lumber to Individual Pieces (e.g. Wall Plates, Sill Plates) SoftList Mode - How to Make a Simple Calculation Change on a Formula Such as a Concrete Wall (Cubic Yards to Lineal Feet) SoftView - How to Add a Custom Texture SoftView - How to Draw 3D Profiles SoftView - How to Change Pens on Saved Elevations (Layer Pens) System Management - How to Set-up Keyboard Shortcuts for Specific Commands System Management - How to Set-up the Toolbar as well as the Floating Toolbar System Management - How to Set-up a Custom Icon for a Specific Library or Symbol System Management - How to Set-up and Use Custom Drawing Modes Tips and Tricks - Using SoftPlan and Windows Clipboard Tips and Tricks - How to Effectively Use the Multiple Select Tool Comments: You will receive a confirmation via email from training@softplan.com.
