Auto Dimension
Auto Dimension of drawings with angled walls improved.
Dimension Point
Stairs work with the Dimension Point command.
Enlarged Dimension Numbers
Locating items in close proximity to enlarged Dimension Numbers is more intuitive.
Move
A Dimension that is moved will stay at the new location on subsequent edits, formerly it would reset to it's original location.
Splines
Shape Splines or Solid 3D Splines can no longer be dimensioned.
Wall Joins
Joining of walls that meet on a opposing side of a wall that are very slightly offset from each other is improved.
Wall Thickness
Wall thickness Dimensions will move to the side of the wall that is unobstructed by items such as Symbols and Closet Shelves when possible.
When working in tight areas it is now easier to select items that are close to wall thickness dimensions.
Wall Thickness dimensions are more difficult to inadvertently select.
Wall Thickness Dimensions are placed outside of exterior walls.
