IDs
Opening IDs properly increment when some Openings in a project have their IDs disabled.
Reverse
The swing on a reversed unit or a single opening with a non-prehung door reverses correctly.
Schedules
Window Schedule and Door Schedule commands added. Window and Door Schedules can be generated separately from each other.
Opening Header Type column added to Opening Schedules.
Units display Hinge side when the Elevation column is included in an Opening Schedule.
Top of Opening added to available columns for the Opening Schedule, lists the distance between the bottom of the wall and the top of the opening.
Units display Hinge direction, left right, in the Hinge column of the Opening Schedule.
Shower Doors
Sliding Shower Door library added to Interior Openings.
