Auto Dimension
Auto Dimension of drawings with angled walls improved.
Complex Walls
Top of Wall & Bottom of Wall options tabs added. These are used to manipulate a single wall so to have multiple heights, steps, slopes and offsets.
The image below shows just two walls, the brick wall on the main floor above the concrete wall on the foundation.
Note: Openings can be placed at the transition between wall sections of different heights and offsets.
End Treatment
If the outside material of the old wall and the new wall have a matching join group (siding A to siding A or Siding B) when using the Change Wall command the End Treatment will remain and not be reset.
Corner Boards extend to meet the Soffit by default when applied to a gable wall under a shed roof.
Floor System
Adjust Wall Surface to Cover Floor command improved.
Ultra High Definition Monitors
Wall Definition dialog sizing improved on UHD Monitors.
Wall Type
Safeguards put in to protect Wall Definitions as they are introduced into a drawing via Merge or Copy/Paste.
2 Hour Fire Wall (Part Wall) type added to default Extended wall list.
