STONE ACCENT WINDOW TRIM
15 replies to this topic
#1 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 09:26 AM
Does anyone know how to do this detail in softplan?  I was thinking of using the soldier window trim, but would then need a stone trim texture?  I tried making the soldier textures wider, but it didn't seem to work.
#2 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 09:37 AM
It seems that I cannot control the width of the soldier or the rowlock settings on the exterior trim tab of the opening.
#3 Yvon Gonthier
Posted 05 February 2018 - 09:44 AM
Are you looking to save as a Softplan line drawing or for 3D?
The width of the soldier or rowlock is controlled in the Drawing Options>Material Dimensions>Material Options. You can adjust tehre as long as you don't have brick somewhere else on tthe plan that this will affect.
#4 Yvon Gonthier
Posted 05 February 2018 - 09:47 AM
For precast contours or quoins in 3D, I use the texture of a concrete block to have atextured effect with joints and adjust size as needed(only draw back is you can't control the exact joint locations). Know, that will work for straight pieces but would need something else for arches.
#5 Richard Rubinski
  • 632 posts
Posted 05 February 2018 - 09:53 AM
Brad,
You can try Cast, then you can adjust the width. I hope this helps.
Rick
#6 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 09:55 AM
I can always fix the line drawings.  Really I would like to be able to show correctly in 3d.  I have both an arch and a straight detail above the garage doors.
#7 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 10:28 AM
I was able to get pretty close by adjusting the brick size in material options.  Thanks for the ideas.
It would be nice to be able to adjust the brick size for each opening trim without changing the entire drawing.  This time it will work ok, since the remainder of the drawing is all stone, but if it were brick i'm not sure how to do that.
#8 Keith Almond
  • 5,127 posts
Posted 05 February 2018 - 10:40 AM
Agreed ... EVERY setting should be able to be over-riden for custom objects, openings, trim etc.
#9 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 11:39 AM
  • Attached File  31.jpg   158.9KB   3 downloads
  • Brent Hyndman likes this
#10 Tom Rogers
Posted 05 February 2018 - 11:46 AM
Very nice looking elevation Brad.  What grass and driveway textures did you use?
#11 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 11:53 AM
I don't know where I got them, but here they are.
  • Tom Rogers likes this
#12 Brad Graber
Brad Graber
  • 296 posts
Posted 05 February 2018 - 11:55 AM
Turns out the grass texture was too big to upload.
  • Joseph Smith likes this
#13 Allen McDonnell
  • 965 posts
  • LocationIllinois
Posted 06 February 2018 - 02:49 PM
Nice, Nice, Nice Brad.....great work.
#14 Joseph Smith
Joseph Smith
  • 833 posts
  • LocationWI
Posted 08 February 2018 - 10:37 AM
Nice work Brad!  Few examples of stone i'm showing in the foreground were symbols I painfully created using the elevations to create 3d stones then copy as them & mirror them, when complete i exported to .3ds then imported to symbol wizard.  Getting something like this in SP programming would be near to impossible IMO.
No the stone symbols are NOT meant for the house in the background....just my current project in the back.
Again nice render Brad!
Joseph A. Smith
http://granitedesigngroup.com
#15 Mark Petri
  • 1,597 posts
Posted 08 February 2018 - 05:17 PM
I typically creat things like that in SketchUp and import. It goes pretty quick, especially if you can use the SP model and trace the openings or have good dimensions. I had one job where they wanted stucco arches over all the openings (which were square windows and doors). Once I figured out the formula building the trim in SketchUp was much quicker. But, I also tried some with a custom pediment symbol. That was a lot of trial and error.
#16 Brad Graber
Brad Graber
  • 296 posts
Posted 09 February 2018 - 08:04 AM
One of these days I will try and learn sketchup for those things.  Every couple of years I try and draw something and just end up frustrated.  However I do download things from there from time to time.
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
