Hip roof with same peak height, different soffit height
roof
#1 Peter Nauta
Peter Nauta
  • 31 posts
Posted 31 July 2025 - 09:45 AM
Hello all,
I have this simple garage project to work on, modifying an older plan of ours and raising the car-port section from 9'1" to 13'0" tall.
I've got it put into 3D as all 9'1" totally fine.
I've run into some trouble getting the two roofs to line up properly, at both the wall and soffit/gutter.  Plus the 2 roof peaks, as the 2nd roof on the car port wants to orient the roof ridge peak forward and back rathe than left to right.
I've exhausted myself of ideas of how to make it tie in properly.
Anyone have any ideas ?
Peter Nauta
Nauta Home Designs
3D Designer
Softplan Computer
i7-6700K @4.00GHz
32GB DDR4
GTX 980Ti
Lumion Computer
16GB RAM
GEFORCE RTX 3070
#2 Rick Kingsbury
Rick Kingsbury
  • 179 posts
  • LocationSpearfish, SD
Posted 31 July 2025 - 09:54 AM
Set the top beam height to 13'0". Be sure to uncheck cleanup on the beams.
#3 Peter Nauta
Peter Nauta
  • 31 posts
Posted 31 July 2025 - 10:27 AM
Ok, I have not tried unchecking the clean up on the beams.  I will let you know how it turned out, thank you Rick.
  • Rick Kingsbury likes this
Peter Nauta
Nauta Home Designs
3D Designer
Softplan Computer
i7-6700K @4.00GHz
32GB DDR4
GTX 980Ti
Lumion Computer
16GB RAM
GEFORCE RTX 3070
#4 Bill Wimberley
Bill Wimberley
  • 680 posts
  • LocationSan Angelo, TX
Posted 31 July 2025 - 10:43 AM
The front beam of the carport will need to move back. How far? Depends on the roof pitch and the actual difference between the 9'-1" (exactly 9'-1"?) and the 13' (exactly 13'?).
You can use the calculator to figure out how far to move the beam back. Enter the roof pitch as Pitch. Enter the difference between the wall height and the top of the beam as Rise. The resulting Run will be how far to move the beam back from the front wall.
#5 Gary Wicklund
Gary Wicklund
  • 236 posts
  • LocationDuncan BC Canada
Posted 02 August 2025 - 08:32 AM
As Bill mentioned, both front and rear beams will need to move together and set to 13’ top of beam to get the look of the 2d and have the ridge line up. Of course side beam set to 13’ also.
your covered area will probably decrease by about a third of the existing building depth(depending on roof pitch)
do you have a right 2d elevation? It will show the difference.
Also tagged with one or more of these keywords: roof
