So I'm having an interesting problem, and the attached picture will be a necessary reference for what I'm describing. I'm working on a house where I have 3 players on the proverbial field: the 2-story main house, the 1-story dining room (Left side of picture), and the scissor-truss porch. All three of these have a different height, and in order to get the Porch roof to play nicely with its ceiling, it has to be drawn as part of the main floor. The rest of the roof is a multi-floor roof, which places it on the second floor. For some reason, and I cannot finagle my way into compliance, the left side of the porch behaves nicely, but the right side refuses. Both walls are set to 9' tall walls, offset by the thickness of the floor system, choosing the "Cover Floor" option for wall surfaces. Both have the same second story wall on top of them. For the left wall, I've also chosen the "Fit to Soffit" option, but for the right wall, choosing that same option makes the brick extend all the way up to the second story roof, covering the window and siding. The Porch roof can be set to reference either side of the wall, can be set as an Intersect, a Gable, or a Vertical Hip, I can check or uncheck Soffit on any roof edge that offers it, but nothing I do will make the wall surface reference the correct roof.
There is one way that I can temporarily make the change work: If I set the second story roof to Building Option 1, turn off that building option, choose the "Fit to Soffit" option, turn back on the building option, then switch the roof back to Default Building Option, the wall will temporarily behave as I want it to, but anything that causes the model to regenerate (even if item cleanup is unchecked) will cause the wall to once again reference the upper roof, even if it's on a different building option. Basically, if the upper roof is visible, the bricks are northward bound.
On one hand, yes, I could choose the "Fit to ceiling" option for the wall. I've already sacrificed the "draw it how it's built" principle by drawing the wall as if it's 2 separate walls for the first and second floor in order to accommodate the two different exteriors. That being said, I'd much rather my framing view have a few extra feet of wall plates than overlapping walls that have the potential to mess with the model construction if a cleanup gets cantankerous.
Ultimately, I think this is another symptom of Softplan struggling when items don't neatly fall into "main floor/second floor" definitions. It would be nice, within the "Adjust Wall Surface to..." section, be able to (a) choose which roof gets referenced when fitting materials to soffit, and (
add some version where, either in the "transition materials height" portion of the wall definition or the materials adjustment menu, be able to divide materials based off a roof and/or ceiling.
Thanks for reading my one-act play, and may the Force be with you.
