Linen and Pantry Shelves
7 replies to this topic
#1 Guest_Kaleigh_*
Guest_Kaleigh_*
Posted 18 April 2016 - 11:35 AM
Is there an easy/quick way to do linen and pantry shelving?   I do not want to use the rod/shelf tool, because i do not want that deep of a shelf, and i dont want a rod...  i know you can change the depth of the rod/shelf...    but is there a way to remove the rod?  or another tool to use for pantry/linen shelves?  Thanks!
#2 Jason Bishop
Jason Bishop
  • 295 posts
Posted 18 April 2016 - 12:09 PM
Uncheck the box for 'Rod'. Change the shelve to the desired width. You can also change the number of shelves and spacing as needed.
Posted 18 April 2016 - 12:16 PM
You would do it with the rod/shelf tool. All the shelf parameters are adjustable, and the standards are just defaults. So you can alter the depth the offset and the spacing, to make it 4 shelves, and you can simply uncheck the rod setting to remove the rod.
#4 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 18 April 2016 - 01:05 PM
When you edit the rod and shelf you can change its' depth and also uncheck the box for "rod" to show it as a shelf.
#5 Guest_Kaleigh_*
Guest_Kaleigh_*
Posted 19 April 2016 - 07:23 AM
Omgoodness I cannot believe I missed that! Thank you all so much!
#6 Guest_Jackson_*
Guest_Jackson_*
Posted 28 October 2021 - 07:29 AM
Why is the RS label still on the shelves when the Rod is Removed?  Shouldn't it just say S.  Or shelves with the number.  Something.
#7 Gary McKeon
  • 557 posts
Posted 28 October 2021 - 10:38 AM
The "RS" isn't something that prints. That is just the lollipop to show you what it is referencing.
#8 David Zawadzki
  • 658 posts
Posted 28 October 2021 - 12:31 PM
It's a reference marker, not a label.
