Hello, This will probably sound like a newbie question but I can't figure it out. I've worked on softplan for 3 years now and just started to really get in the renderings. I've seen some renderings that have the grass that looks like baseball fields. Ask someone on Facebook and they said it's a texture on the program. I've looked and can't find it anywhere. Am I doing something wrong.
grass texture
Posted 23 February 2015 - 07:35 PM
You can often find textures by searching Google images.
There are also several sights which specialize in textures.
It is easy to modify one of the Softplan grass textures with a paint program
- Matt Orner likes this
-Chris
Posted 23 February 2015 - 07:36 PM
you can do a google texture search for grass.
i saved a few > the ones that look fairly realistic
are a photograhp of a large sections of a grass area and check
"scale" when editing the surface.
look for a large jpg at the least (bmp or png might be better) and put them
in your 3d / texture / bmp / site / grass - folder.
remember to check "SCALE" when editing that surface.
that might work for you.
tip: also look for seamless grass textures
- Matt Orner and Thomas Kreun like this
v10 to future 2016+
#10
Posted 24 February 2015 - 09:55 AM
I posted this link in the old forum. There are over 30K textures & 3D models. I think this is where Derek's striped grass came from.
http://www.sketchuptexture.com/
#11
Posted 27 February 2015 - 08:38 PM
you can put too solids like splines together with
the same mowed grass texture but editing the
one that's a little higher with it having an "opacity"
(so you can see thru it to the lower texture)
and also having the upper splines texture "rotated"
and this way the lower one shows thru.
note:
the actual texture is with the mowed strips
go only in one direction.
note: the golf cart and golfers are from sketchup.
the people are jpgs and exported as models
and the golf cart is a 3ds model exported
and than used the "symbol wizard" in softplan..
v10 to future 2016+
