I can't decide whether I'm having a senior moment, or this can't be done. How would I create a staircase like this?
Posted 31 August 2016 - 01:22 PM
Posted 31 August 2016 - 07:39 PM
showing the stairs you illustrate made
with lines and arcs
and
than use
EDIT / FORM SOLID POLYGON
left CLICK to enlarge
NOTE:
not sure we can do them with the "stair" program but could be wrong.
NOTE 2:
if we can't do them, i'm sure softplan tech will add this feature
to the next upgrade.
v10 to future 2016+
Posted 31 August 2016 - 07:57 PM
This is done with 3 sections of flared stairs. Setting the flare to "0". Using the appropriate "alignment". and adding a deflection to the center section. It works for the 3D but you would have to do the plan view with lines and make the stairs hidden.
It might just be quicker with Randy's method.
Posted 31 August 2016 - 08:23 PM
James,
Thanks, that's exactly what I was trying to do. I could easily make lines and arcs work, but somehow it seems more right to draw stairs as stairs if I can.
However, I may be thick, but I can't see what you did to make that work, that I haven't tried, but my attempts aren't even close to that. Can you explain in a little more detail please. Obviously, I'm missing something fundamental.
Thanks.
... It works for the 3D but you would have to do the plan view with lines and make the stairs hidden ...
I ALWAYS make my 3D stairs hidden and then draw them as lines on the plans otherwise they just look bad/wrong on the plans. Typically on the basement you have to show what's under them, and on the main floor they are invariably partly under the framed opening. neither of which Softplan can cope with and still show the plans neatly in my opinion. The generated staircase section line is just awful.
Posted 01 September 2016 - 06:37 AM
James,
Thank you. Now I see what you did. I couldn't see how the 4th riser was curved - I always ended up with it straight - but it's part of the deck ... clever, I hadn't thought of that.
Posted 01 September 2016 - 12:32 PM
I hate drawing stairs as lines that is why I often draw partial stairs.
That's why my suggestion was that stairs should have an option for an adjustable section line meaning that you can adjust the height at which it cuts thru your stair (same principal as walls). Then, for the portion above the section line, you have the option to show dashed lines or nothing. Oh yes, and improve the section line.
Posted 01 September 2016 - 02:41 PM
james, nice thinking outside the "stair box"
for this particular stair design,
I like the way the wood curves with the steps.
I use the line and arc method because I've been doing
it for almost 20 years and can do it fairly fast.
too much thinking for me using your method
but the finished result is very good.
you should send a "suggestion" to softplan tech
about adding these types of steps to the stair menu(s).
I do think softplan users should learn how to use
lines and arcs / form solid polygon /
for many of their 3d objects.
note: the lines and arcs that you draw work well
for your 2d con docs as well as the 3d models
you can get from them.
v10 to future 2016+
Posted 02 September 2016 - 10:03 AM
the problem Randy comes when you generate a material list. About half my projects I do a take off for. Solids don't always cut it when you order the materials. Now for a Rendering-absolutely!
Posted 02 September 2016 - 10:20 AM
I hear you tom, but I only design >
would never do take offs for my clients
OR contractors',
can only get me into trouble.
don't want the liability.
how accurate can SP do stairs ?
btw,
you can save the 3d model you make as a 3d symbol
for use in future projects with a similar design.
you could build this stair with individual pieces
just like you'd build it so it could work with soft list.
v10 to future 2016+
Posted 02 September 2016 - 10:49 AM
Actually the take-offs are pretty good. Our rules are a little bit more relaxed than Cailifornia. And I always tell my builders that there is not wastage factor in there since I cant tell the framer how to cut the pieces so that usually takes care of them coming back and crying about it. But when I had one builder complain that he took back a semi full of stuff I tell him that my builders who use my material list return about oine bundle of shingles, they are happy for the money I can save them.
I do like the idea of using it as a symbol. And if I can get a set price for a turn-key stair price that would be perfect.
SoftPlan →
General Questions →
Stairs / Auto-BasementStarted by Steve Gray , 19 Sep 2023 |
SoftPlan →
SoftPlan version 2020 →
Winder stairs to fit CodeStarted by Ben Ginther , 12 Feb 2021 |
SoftPlan →
General Questions →
Stairs, Stairwells, and Multiple FloorsStarted by Adam Marquart , 25 Feb 2020 |
SoftPlan →
SoftPlan 2016 →
Round StairsStarted by Samantha Tennant , 12 Aug 2016 |
