interior elevation
#1 Guest_Dan_*
Guest_Dan_*
Posted 19 March 2015 - 07:05 PM
I'm trying to create an interior elevation of some cabinets.  I put the view point in but when the elevation comes up its cut off on the sides as if it being looked at through an opening.  there is nothing else on the drawing no walls or doors just cabinets.  probably a really easy fix but getting super frustrated.
#2 randolph cohn
Posted 19 March 2015 - 07:07 PM
check and make sure your "CEILING" is at the correct ELEVATION.
#3 Ron Globke
Ron Globke
  • 20 posts
  • LocationDayton - Cincinnati, Ohio
Posted 20 March 2015 - 10:58 AM
Now with 2016 you can put it into the model and go down to Presentation View and click on that file.  That will take off the ceiling and you should be able to look at it that way.  Them move around is a little slow with just the arrows, but if you zoom_center on the drawing it will come into view quicker then you can use your center mouse button to orbit around it.
Softplan User Since 1996 (Softplan 2016+)
#4 Guest_Guest_*
Guest_Guest_*
Posted 21 March 2015 - 01:08 PM
Randy I'm not seeing a ceiling option.  Its almost as if the view is through a door opening even though there isn't any walls
Posted 21 March 2015 - 01:20 PM
When you create an interior elevation Softplan draws an elevation marker, and a dotted line representing the length of the elevation (at least it does in 2014 - can't guarantee what 2016 does yet!) - Use adjust to increase the length of this line and re-create/regenerate the elevation. Does that make any difference?
