Disappearing Walls
17 replies to this topic
#1 Jason Bishop
Jason Bishop
  • 295 posts
Posted 09 July 2017 - 04:46 PM
Has this issue been resolved yet?
It is very frustrating having to close and reopen drawings, multiple times I might add, to get walls to reappear and it is very unprofessional (and embarrassing) when making simple adjustments in front of a customer and have this happen.
JLB
  • Cory Ewing likes this
#2 Martin Livingston
Martin Livingston
  • 693 posts
Posted 09 July 2017 - 04:51 PM
I agree! I had to replace some PDF files for a meeting and had to reload the drawings several times to make the walls reappear.
www.cresco.ca
#3 randolph cohn
Posted 10 July 2017 - 04:38 PM
try opening up a new blank drawing and put the word
MERGE into the file name.
than leaving this new blank "merge" drawing open
and go to / file /  merge / and locate the bad drawing
and click on it.  your old file will "merge" with the
newly named "MERGE" file drawing and usually
it'll fix the problem on the old file.
this has usually worked in the past when a problem on
a drawing occured.  MOST ANY PROBLEM.
#4 Fred Russell
Fred Russell
  • 620 posts
Posted 10 July 2017 - 09:34 PM
I just had some of the walls disappear on me. I could still edit where the wall is altho I couldn't see it and it would edit the wall.  I shut down the program and restarted and it was corrected.
had just done some 3D viewing inside
#5 Brad Graber
Brad Graber
  • 295 posts
Posted 11 July 2017 - 09:10 AM
i've been having it happen a lot.  I agree would really like to see it fixed, as it never had this issue before.  My solution has been to remove the drawing from the multi drawing and then reinsert it into a multi drawing and the problem seems to be fixed.
#6 Paul James
Paul James
  • 251 posts
Posted 11 July 2017 - 11:55 AM
I've right clicked select type and cleaned up items- that seems to work.
#7 Dave Pazyniak
Dave Pazyniak
Posted 12 July 2017 - 06:56 AM
Is this related or the same issue?  My plan set prints fine.  When I reopen the drawing, some pages have some walls missing, others of the same type still appear.  My fix has been to remove the drawing from the page and reinsert it.  next day when I come back in, it is missing walls again...
#8 Heath Foster
Heath Foster
  • 177 posts
Posted 12 July 2017 - 07:29 AM
Try just moving the plan. I do move then right click to cancel and it redraws it.
#9 Tom Rogers
Posted 13 July 2017 - 09:36 AM
Yes Dave, that is also an issue that is happening as well.
#10 Tom Rogers
Posted 14 July 2017 - 06:25 PM
Any news Brent on this issue?
#11 Keith Almond
Posted 17 July 2017 - 09:29 AM
I'm missing walls on my Plansets that are showing on the standard plans. is this the issue everyone else is seeing or something different?
Attached File  2017.07.17_11h26m43s_001.png   66.76KB   0 downloads
#12 Tom Rogers
Posted 17 July 2017 - 09:40 AM
This is the problem Keith.  Tech is and has been working on a fix.  It has been a while so I am guessing it is pretty big problem
#13 Guest_Derrik Bauer_*
  • Guests
Yes Keith, this is the issue.  I have also had it happen on multiple pages of a SoftList report.  Numerous tickets have been created, I assume a fix is in the works.
Typically a re-start does the trick.
*****Tom you're fast!******
#14 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 17 July 2017 - 12:27 PM
Tech is aware of the problem.  The word I got is that they think it may have something to do with other opened tabs.  Close any tabs that are open that also have the drawing on them that you are working on.  Then hit Ctrl-R to redraw and all should be good.
#15 Keith Almond
Posted 17 July 2017 - 12:53 PM
I don't know how others work, but switching drawings and tabs to me is an essential way of working. I ALWAYS have ALL RELEVANT drawings in a project open at the same time, and ALL pages of the planset. Closing tabs and then having to re-open them to work is a definite workaround, not a solution.
#16 Josh Friesen
Josh Friesen
  • 8 posts
  • LocationWinnipeg
Posted 17 July 2017 - 03:09 PM
I got this response when i filed a support ticket. Hopefully this newest version has fixed the problem. I had walls disappearing randomly on me.
We are aware of an issue that can cause the visibility flag to flip on the walls. Going to Options>Visible Items and flipping the walls off, then on, should make them visible again. Development is looking into the issue.
#17 Tim Stockton
Tim Stockton
  • 313 posts
Posted 17 July 2017 - 07:52 PM
I think you just have to bear with it for a little while until tech can get a patch out.  Ideally we like to have drawing tabs opened up for different looks, etc.  They are working on a fix and I have confidence they will get it out soon.  Just part of the growing pains of an improving system...
#18 Brad Graber
Brad Graber
  • 295 posts
Posted 18 July 2017 - 07:20 AM
New patch just out this morning....Looks like a lot of good stuff included.
What’s New | 2018.4.0
DWF Import – Embedded Images
Changes have been made to ensure that embedded images in DWF files will now import.
The image is drawn degraded in SoftPlan, but will print out at its full resolution.
Interior Elevations – Reverse
When all or part of a drawing is reversed that includes an interior elevation view, the interior elevation view will now update correctly.
Tables/Schedules – Multiple Cell Changes
Changes have been made to ensure that lag time is minimized when a change is made to multiple cells in a table or schedule (e.g., selecting all cells in a table and changing the text font).
REScheck – Raked Wall Area
Changes have been made to ensure that REScheck accurately calculates wall area on walls that are raked.
Stacked Opening Display – Mullions
Changes have been made to ensure that mullions that overlap openings do not draw in plan view.
Temporary Dimensions – On/Off
Disabling the Display Temporary Dimensions function in System Options  Setup Options turns off the faded dimension preview function for all dimension-related commands and edits.
Changing the System Options changes system settings for all new drawings.
Interior Flooring Polygon – Area
Changes have been made to ensure that the Area listed for an interior flooring polygon updates correctly when the size of the flooring polygon is adjusted.
Roof Options – Roof Material Thickness
The ability to set the default Roof Material Thickness for roof shingles has been added.
Program default value for Roof Material Thickness is ⅛”.
Roof Options – Roof Material Overhang
The ability to set the default Roof Material Overhang has been added.
Program default value for Roof Material Overhang is ¾”.
Speed Notes – PDF Export
Changes have been made to ensure that speed notes included with a drawing in one drawing mode (e.g., Floor System mode) do not affect the PDF export of that same drawing in a different drawing mode (e.g., Drawing mode).
DWG Export – Arc and Circle Smoothing
The default minimum smoothing value of arcs and circles during DWG exports has been increased to ensure smoother, better looking circles and arcs in DWG export files.
Offset – Curved Site Line
Changes have been made to ensure that offsetting a curved site line that had its center reversed works correctly and offsets on the side selected.
Wall Redraw
Changes have been made to ensure that walls redraw correctly when a single drawing is placed in a plan set in multiple modes.
