Is there a way to do an exterior elevation at an angle?
In the attached project the piece at the left with the windows above the door is the indoor pool. In my drawing the centre part of the house is straight and the pool at the left and the garage at the right are angled.
My engineer is requesting elevations showing the end walls of the pool so that he can do the structural designing for those walls.
If I just do the default front and rear elevation views those angled walls will be distorted.
I thought of generating a framing view, but this is a composite wall and not with standard framing, so the way I defined it, it is not showing up on the drawing if I generate a framing plan. Front View.jpg 102.46KB 0 downloads
