Plan Sets.. Default to 1/4"?
26 replies to this topic
#1 Jon Davis
Jon Davis
  • 541 posts
Posted 07 May 2019 - 07:45 AM
I've looked and can't find a setting to make my drawings default to 1/4" when adding it to the
plan set sheet. Typically all our drawings are 1/4" = 1'. Would be nice to set that as the default
when adding a drawing to a sheet.
  • Paul James, Bernard Toews, Keith Almond and 3 others like this
#2 Philip Frank
Philip Frank
  • 560 posts
  • LocationMaine, USA
Posted 07 May 2019 - 08:02 AM
I agree
#3 Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 07 May 2019 - 03:12 PM
Well that would only be correct %99.99 of the time.  Do we really "need" a default?
#4 Paul James
Paul James
  • 251 posts
Posted 07 May 2019 - 06:16 PM
I agree- coming in at 3/8" is really dumb and annoying.
But give us the option to set the default we want-
#5 Mark Petri
  • 1,516 posts
Posted 08 May 2019 - 10:14 AM
Ditto!
#6 Jon Davis
Jon Davis
  • 541 posts
Posted 14 May 2019 - 08:18 AM
Hey SP, any thoughts on this?
#7 Tom McConnell
Tom McConnell
  • 277 posts
  • LocationSaint Augustine, Florida
Posted 16 May 2019 - 09:01 AM
Yes. Default to 1/4 !!
SoftPlan+ 2021
SP since 2012, AutoCAD since 1994
OS - Windows 10.0 Pro 64 Bit
CPU - AMD RYZEN 9 3900X 12-CORE
MB - ASUS ROG Strix X570-E
RAM - CORSAIR VENGEANCE RGB PRO 32GB DDR4
Graphics - ASUS ROG Strix Radeon RX 570 O4G Gaming OC Edition
3 - ASUS MX279H 27 Inch LED Monitors
3Dconnexion CadMouse
Corsair K95 RGB Cherry MX Brown Keyboard
#8 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 16 May 2019 - 09:35 AM
Yes, the default selection should be available.
Please !
#9 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 22 May 2019 - 07:49 AM
A suggestion has been made to allow a default scale to be used when adding drawings to a plan set.
  • Warren Ducote, Michael Landry, Keith Almond and 2 others like this
#10 Michael Collazo
Michael Collazo
  • 102 posts
Posted 22 May 2019 - 10:54 AM
If a suggestion is made, it would be best to allow us to set what that default is at the project level, and in addition, if we like drawing level (for detail templates). Thanks.
  • Gary McKeon likes this
Michael A Collazo
Planmark Design Studio, LLC
Tampa, Florida
http://planmarkstudio.com
info@planmarkstudio.com
#11 Philip Frank
Philip Frank
  • 560 posts
Posted 23 May 2019 - 05:14 AM
If you use PlanSet Templates, you can create a template sheet for your elevations and prepopulate it with your 4 elevations set to your preferred scale. Now when you create your PlanSet from that template  for your specific project the scale is set and the elevations are already on the sheet. At most you need to rearrange the elevations on the sheet.
  • Brent Hyndman likes this
#12 Jon Davis
Jon Davis
  • 541 posts
Posted 24 May 2019 - 09:06 AM
I have templates set up, but they still jump to whatever scale they want when adding drawings to sheets.
#13 Keith Almond
  • 5,101 posts
Posted 24 May 2019 - 10:15 AM
What Phil was describing about the template, means that you don't add a drawing ... the drawing is already added to the template.
Softplan tries to fill whatever space it has on the sheet with the biggest scale available.
#14 Jon Davis
Jon Davis
  • 541 posts
Posted 30 May 2019 - 06:24 PM
Yeah, but that doesn't really work for me either since I don't always have the same-named drawings to put on sheets in every new file. It only works
if you have drawings that are named exactly the same in each file.
#15 Gary McKeon
Gary McKeon
  • 562 posts
  • LocationSilverton Oregon
Posted 30 May 2019 - 06:45 PM
Yep.
#16 Keith Almond
  • 5,101 posts
Posted 30 May 2019 - 08:18 PM
NO ... When setting up the planset, you can make substitutions into the planset with the Drawing mapping, and you can switch the drawing called "FLOOR PLAN" for one called "FIRST FLOOR" in the drawing mapping in the template when you open the new template.
  • Jim Johnson likes this
#17 Gary McKeon
Gary McKeon
  • 562 posts
Posted 30 May 2019 - 11:46 PM
Keith, I just want to push "one" button. Any more than that and its too much work and really needs to be fixed.  :D
  • Jon Davis likes this
#18 Jon Davis
Jon Davis
  • 541 posts
Posted 03 June 2019 - 11:42 AM
Exactly... lol.. gotta streamline the process. We're building over a 100 houses a year, and we have only 1 draftsman. Me.
#19 Jon Davis
Jon Davis
  • 541 posts
Posted 18 June 2019 - 12:59 PM
For those saying to use Templates, that doesn't work either, at least not for me...
I created this plan set template, the elevations were set to 1/4" = 1' when I created the template from the original plan set.
When I pulled the plan set template into this drawing, it put my elevations on the sheet, but at 3/16" = 1'......
#20 Mark Petri
  • 1,516 posts
Posted 18 June 2019 - 05:01 PM
So, just edit your elevation to 1/4" scale and re-position if needed? You can always use "paint break" or "shade break" lines as guides to snap to if needed. Or, place lines that you have on a layer you turn off before printing or set not to print. Lots of options depending on how you are doing your plan sets. I think templates are still faster than starting from scratch if you do a lot of the same drawings.
