Dimensions for elevations
Dimensioning
#1 Joshua Brown
Joshua Brown
  • 14 posts
Posted 26 May 2015 - 06:41 PM
Hello,
I am very new to SoftPlan (been using it for about a month) so getting used to it has been a struggle since I am in a situation were I am trying to learn the software and do work with it at the same time. My question is pertaining to dimensioning elevations. I want to dimension a design for an Egress Window showing the framing dimensions, the size of the window, and the dimensions in relation to the wall. I attached a PNG of the 3D view. Thank you for your time and I will probably be posting a lot here and any help is appreciated.
Edit: Is there also a way I can input dimensions manually from there?
#2 Martin Livingston
  • 671 posts
Posted 26 May 2015 - 06:52 PM
If you want to detail an elevation you need to save it as a Softplan drawing ( file/save as). This will create an editable drawing file which you can later add to your plan sets.
  • Joshua Brown likes this
#3 Joshua Brown
Joshua Brown
  • 14 posts
Posted 26 May 2015 - 07:02 PM
Thank you very much Martin. This is what I needed.
