Annotated Elevations Unwanted Lines
1 reply to this topic
#1 Tom McConnell
Tom McConnell
  • 277 posts
  • LocationSaint Augustine, Florida
Posted 16 May 2019 - 08:50 AM
There needs to be a way to remove or mask*** unwanted lines generated in annotated elevations.
This can happen when two walls butt, tricky roof planes that are impossible to align, etc...
It's like SP needs to create a virtual line drawing that can be edited and regenerated when plan changes are made.
Could this be done with Layering or the New "Annotated Elevation Modes" (I made this up so cut me in $ (free SP for life))?
  • Generated drawing on bottom layer
  • Paint on the next layer above
  • Notes on the layer above that
*** If you use a mask it painting must ignore the mask and the line below the mask, so I don't think masking is SP's best solution.
Lipstick on a pig.
SoftPlan+ 2021
SP since 2012, AutoCAD since 1994
OS - Windows 10.0 Pro 64 Bit
CPU - AMD RYZEN 9 3900X 12-CORE
MB - ASUS ROG Strix X570-E
RAM - CORSAIR VENGEANCE RGB PRO 32GB DDR4
Graphics - ASUS ROG Strix Radeon RX 570 O4G Gaming OC Edition
3 - ASUS MX279H 27 Inch LED Monitors
3Dconnexion CadMouse
Corsair K95 RGB Cherry MX Brown Keyboard
#2 Tom McConnell
Tom McConnell
  • 277 posts
Posted 16 May 2019 - 11:42 AM
The concept of Annotated Elevations limitations and workflow has been answered by John Pepper here:
http://softplan.com/...ess/#entry25273
SoftPlan+ 2021
Also tagged with one or more of these keywords: Annotated, Elevations, Unwanted Lines
