Dormer shaft. Hole in roof / Hole in Ceiling -> Add Drywall not working
Dormer Hole in roof Hole in Ceiling Add Drywall
#1 Tom McConnell
Tom McConnell
  • 277 posts
Posted 26 December 2019 - 05:01 PM
I having to put 3D text "PROGRAM WILL NOT CREATE DORMER SHAFT WALLS" because I hole in roof or hole in ceiling add drywall does not work.
I usually can find a work around but not this time.
Ceiling is sloped and roof is slope (obviously).
Anyone have a work around.
Attached File  SP14.jpg   65.62KB   0 downloads
Attached File  SP15.jpg   58.9KB   0 downloads
Attached File  SP16.jpg   81.72KB   0 downloads
SoftPlan+ 2021
OS - Windows 10.0 Pro 64 Bit
MB - ASUS ROG Strix X570-E
3Dconnexion CadMouse
#2 Jim Johnson
Jim Johnson
  • 289 posts
Posted 26 December 2019 - 07:06 PM
You can use Solid>Wedges and inverted Wedges.  Or you can take a cross section and create a Solid Polygon, create a symbol and rotate it with the symbol wizard.
#3 Tom McConnell
Tom McConnell
  • 277 posts
Posted 27 December 2019 - 09:10 AM
Wedges
Wedges became very time consuming adjusting then losing what I had when editing drawing.
Symbols
Seems you can only rotate a symbol if it is linked to a 3D symbols.
When a work around takes hours to figure out, then you lose what you created it becomes extremely frustrating.
For now I am going to have to leave the text "PROGRAM WILL NOT CREATE DORMER SHAFT WALLS".
SoftPlan+ 2021
Posted 27 December 2019 - 09:13 PM
Just draw some walls in the right locations ...  Set at correct height, rake bottom, and fit top to roof ... No, IT won't create Dormer shaft walls. but YOU can, the key is in the original statement ... WALLS.
  • Jim Johnson and Heath Foster like this
#5 Jon Davis
Jon Davis
  • 541 posts
Posted 30 December 2019 - 07:48 AM
I ran into the same thing earlier this year... Never did get it to look right.
#6 Tom McConnell
Tom McConnell
  • 277 posts
Posted 30 December 2019 - 03:02 PM
Confused. "No, IT won't create Dormer shaft walls. but YOU can, the key is in the original statement ... WALLS."
"No, IT won't create Dormer shaft walls."
I'm trying to create Dormer Walls.
"but YOU can, the key is in the original statement ... WALLS."
How?
Do you have example or procedure?
SoftPlan+ 2021
Posted 30 December 2019 - 03:20 PM
Just draw walls and position to suit. The dormer is already created, all you need to create is the shaft. Four standard walls at the right height should do the trick nicely. Put them on their own layer, and don't hide it.
Also tagged with one or more of these keywords: Dormer, Hole in roof, Hole in Ceiling, Add Drywall
