Joist Join Tolerance
#1 Brian Berzinskis
Brian Berzinskis
  • 470 posts
  • LocationNew Jersey
Posted 20 July 2015 - 01:36 PM
I have a house on pilings and I have my banding beam on the pilings. When I always go to put my joists in they want to snap to the beam instead of having a slight cantilever over the beam. Is there any way to adjust the join tolerance on the joists? My beam is 5 inches in from the outside face of the first floor and always snaps back to the inside of the beam which just looks wrong.
#2 Steve and Carla Farnam
  • 654 posts
Posted 20 July 2015 - 05:45 PM
Brian under the tools tab click on the "Reduce Join Tolerance " tool then use it where the beams rest on the pilings.
You can also reduce manualy by editing and going to the Join Tolerance towards bottom of the edit window
#3 Brian Berzinskis
Brian Berzinskis
  • 470 posts
Posted 21 July 2015 - 05:57 AM
I already have the join tolerance for the beams down to 1 inch but it still snaps the joists to the beam. I am not sure that the join tolerance applies to the joist sets.
#4 Jim Crook
Jim Crook
  • 126 posts
  • LocationGravenhurst, Ontario, Canada
Posted 21 July 2015 - 12:13 PM
Brian have you unchecked "Clean-Up", I'm  not in Softplan right now but I think there is this option in the joist edit menu ?
JimC
#5 Brian Berzinskis
Brian Berzinskis
  • 470 posts
Posted 21 July 2015 - 12:42 PM
JimC
I just tried turning off Clean Up for the joist set but it still wants to snap to the beam. I turned off Clean Up for the beam as well but no luck.
