Covered vaulted deck
6 replies to this topic
#1 Gary Wicklund
Gary Wicklund
  • 162 posts
  • LocationDuncan BC Canada
Posted 09 January 2021 - 06:22 PM
Doing a covered deck with a parachord truss vault
I’ve added the roof , added the ceiling sloping from both sides
how do I get rid of the gable siding and the gable end of the ceiling?
looked through the forums But can’t find any references to exterior vaults
thanks
#2 David Zawadzki
  • 663 posts
Posted 09 January 2021 - 08:47 PM
Did you try unchecking gable wall supplied by roof.
I am not at my computer so bear with me...
Posted 10 January 2021 - 09:07 AM
Edge edit the ceiling and change that edge to gable. If it has a solid end at the moment its a vertical hip.
#4 Gary Wicklund
Gary Wicklund
  • 162 posts
Posted 10 January 2021 - 10:12 AM
Yes, that worked ok, just clearing the ceiling gable was the issue
#5 Gary Wicklund
Gary Wicklund
  • 162 posts
Posted 10 January 2021 - 10:13 AM
Thanks Keith, that was it. I wasn’t editing the edge.
Posted 10 January 2021 - 10:14 AM
Personally, with a parallel chord roof, I normally add 2 ceilings in the same place ... One as thick as the parallel chord to give the exterior finish, and then a standard exterior soffit finish below that to show the ceiling finish.
#7 Gary Wicklund
Gary Wicklund
  • 162 posts
Posted 10 January 2021 - 07:00 PM
I’ll give that a try
I used 2 walls top set to roof and raked bottoms to finish off the chord gable
I never thought I could change the ceiling thickness.  Lol
